Pics of my troubled boards #4
  • axlmastr
    • Aug 2005
    • 158
    PC Chips 726MRT
    v1.2A
    I know it's a P.O.S., but it has given 3 years of great service and is configurable for different proc generations. I have two of these in service. I even saved my driver disk, because I know from previous boards of theirs I've worked on, they are a bitch to get correct drivers for. One board has the AMR modem and I have to use the other board's CD for its drivers. Damn I can only imagine if I didn't have the second board to use the driver disk to get the modem to work. Whew! Good upgrade board after you get tired of the Slot 1 and want to put a PIII pull in the socket. Of course, recapping is a PITA with the sizes they use and placement.
    Material list:
    1500uF 6.3V (8) Canicon
    1000uF 10V (7) G-Luxon
    470uF 16V (10) G-Luxon
    100uF 16V (2) G-Luxon
    22uF 25V (1) G-Luxon
    10uF 25V (14) G-Luxon
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Pics of my troubled boards #4
    "Canicon"
    That's a brand I dont ever remember seeing....
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • axlmastr
      • Aug 2005
      • 158
      @Topcat
      I'll post a pic of the elusive Canicon when I re-cap the board. It's real!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        canicon are a well known crap brand.
        not a common as others but i have seen lots of bad ones.
        i pulled some from a video card last week.i will see if i can find them and post a pic.
        • yanz
          • Nov 2004
          • 910
          i have them on a celeron motherboard (tx?). 10 x 1000uF 6.3v. bulged - leaked.
          days are so short when you actually do something..
          • ugamazing
            by ugamazing
            12-17-2024, 07:05 PM
          • ugamazing
            Apple M1 Boards & Exclamatory Error?
            by ugamazing
            We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
            Has anyone else run into this...
            02-20-2025, 09:24 AM
          • ugamazing
            Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
            by ugamazing
            I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
            08-31-2022, 07:34 AM
          • hopkok
            Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
            by hopkok
            Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
            3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
            I checked for low resistance on coils, no low resistance.
            Anyone with same issue like me?
            Thanks for any help.
            05-24-2025, 04:21 AM
          • midnightg35x
            Panasonic TC-P65S2 SU or SD Boards Bad?
            by midnightg35x
            I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
            04-22-2019, 05:29 PM
