Help identifying an old capacitor
  • SirCapsAlot
    • Sep 2021
    • 4
    • Sweden
    I need to replace a blown capacitor that's about 25-30 years old and as far as I can tell it's not manufactured anymore so I'm looking for a equivalent replacement.
    From my limited understanding of reading capacitor codes I think this is a 2200pF +- 20% 250V-400V ceramic Y1-class capacitor (see attached image). Is that correct?
    I assume the 250/400 numbers represent the max voltage according to different certifications?
    It's sitting behind a (now destroyed) 12a 250v slow-blow ceramic fuse by the way.
    Any help with this would be much appreciated!
  • PeteS in CA
    • Aug 2005
    • 3581
    • USA, Unsure of Planet
    Re: Help identifying an old capacitor
    The manufacturer of those parts was Ceramite, a spin-off from Sprague. The series is 30LV. More to the point, Ceramite was bought by Vishay, https://cdn.badcaps-static.com/pdfs/...f797addad4.pdf . They are 2200pF, and any brand's physically compatible Y1-class part could be substituted.
    PeteS in CA
      master hoarder
      • May 2008
      • 12175
      • Bulgaria
      Yes, that's 100% correct.
      Seems like your understanding of reading capacitors isn't so limited after all.
      Now, is there a reason you are replacing this/these capacitors? Capacitance reading low, perhaps? If not, they should be OK. Sure they are quite old at 25+ years, but ceramics (particularly Y1/Y2 class) don't age that badly. I imagine the black soot on it is the reason why? If so, you can just clean that up with IPA.
      Now X1 and X2 class metal film caps are a different story. With age, they can/usually do loose quite a bit of capacitance, especially in noisy environments. Moreover, some of them can fail shorted over time. So X1/X2 caps are more likely to need replacement with advanced age.
      • SirCapsAlot
        • Sep 2021
        • 4
        • Sweden
        Great, thank you both! I was I bit unsure so it's great to get some confirmation.
        Regarding the reason for replacing it. I haven't actually tested the capacitance, I honestly just assumed it was bad when it popped and sprayed soot everywhere haha
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          No problems!
          Well, the question is... did that Y cap really pop and spray soot or is that just residue from the fuse. Clearly if was the cap, then it should be replaced. Otherwise, I'd just clean the soot on it with IPA and not bother with replacing.
          • SirCapsAlot
            • Sep 2021
            • 4
            • Sweden
            No problems!
            Yep it was the cap, can't really see it well in the picture but the lower left darker area is actually a hole where the soot sprayed out of.
            I replaced it and the fuse yesterday and it worked wonders
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              Nice! Good to hear you got to the bottom of it.
              I'm just surprised to see a Y1-type capacitor fail. Usually those are supposed to be very robust and made for industrial environments. But after 25-30 years, I guess it could have seen some abuse throughout its life.
              • chth96
                Is it possible to test small ceramic disc capacitor with analogue meter?
                by chth96
                I read EBOOK of Testing Electronic Component and found that
                "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                Is it really possible to test small ceramic disc capacitor with analogue...
                03-09-2024, 10:03 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • NuclearSpartan
                Samsung C32HG70 - Blown Ceramic Capacitor (CP813)
                by NuclearSpartan
                I'm new to this, so I apologize for not providing enough details. Is there anything else I need to mention? I'm trying to learn more about electronic/board repairs and hopefully fix my own.
                The only visible issue on my board is one capacitor, CP813, which appears to be labeled R 221k 2kV (possibly obsolete to B 221k 2kV now). My monitor hadn't shown any prior issues, although it is a few years old. Just before the capacitor popped, there was a high-pitched squeal for 2–3 seconds.
                I don't see any other visible damage anywhere else on the board....
                11-14-2024, 02:32 PM
              • rictechie
                smd ceramic capacitor use in iphones
                by rictechie
                is there a brand of smd ceramic capacitor use in iphones? or they are generics
                07-26-2024, 08:28 PM
              • paceuser
                Need help identifying Ceramic Capacitor
                by paceuser
                I have the following ceramic capacitor that I would like to identify. I need to purchase another one like it or an equivalent. Here is the text on the capacitor:
                Capacitor is Yellow in color. It has three lines of writing:
                VF05
                0221
                TK RU (RU = Underwriter's Laboratories Logo)
                If anyone knows an equivalent on fleabay please let me know. Thank you I appreciate your help.
                05-14-2020, 07:04 AM
