"Dual" 2004 Plasma TV
  • Oerg866
    • Nov 2009
    • 61
    Hi there :/
    In my living-room there stands a Plasma TV from "Dual". I can't look up the exact model now but maybe you can help.
    The buttons on the remote control became very unresponsive over the last two months. I have to push the power button on the remote like a dozen times and otherwise too I have to push many times until it finally works right.
    Could it be bad caps? It still has great picture and works great otherwise.
    Batterys are not the cause. I changed them many times to see whether that is or not.
  • kaniki
    • 514
    Re: "Dual" 2004 Plasma TV
    sometimes oil from your hands can get on to the board and cause a short where that button will not work. What i would do is take the remote apart, use rubbing alcohol and wipe down the circuit board and the bottom part of the rubber that you push on. I have had to do this with a lot of remotes over the years and is a common problem.
      HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
      This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
      09-12-2024, 02:00 PM
    • cstout
      DeLonghi AC Remote only accepts 3V
      by cstout
      Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
      The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
      I can't find any schematics...
      06-03-2024, 03:53 PM
    • Mc_Millian
      Toshiba 50lf711u20 fire tv remote not pairing
      by Mc_Millian
      I was wondering if anyone could help my in pairing a remote with a Toshiba fire tv?
      The Tv model number is: 50lf711u20 Rev B.
      I've already replaced all the the circuit boards within the tv along with the I.R. sensor receiver.
      I've tried 3 different remotes which should be fully compatible with this TV.
      Oddly enough. A few if the buttons on all of the remotes actually work. Even without pairing...which makes no sense.
      The power button, along with the volume,back,select, and directional...
      04-07-2022, 12:15 PM
    • cmonkey
      Zenith Z50PJ240 - White Screen with 'Power Only' displayed
      by cmonkey
      Turned on my lovely plasma and after about 30 seconds the screen below showed up. None of the inputs are responsive, just the red light flashes when I push it. Remote doesn't work either. To turn it off I need to unplug it and when I plug it in again it turns back on to this screen.
      I only found one reference to this issue with a different model but it didn't look super reliable. Only mentioned a 'main board fault'. The main board for this one is on ebay for $34 so might need to go with that.
      Anyone seen this before?
      Thinking about it some more, it happened...
      05-19-2023, 01:01 PM
    • edugimeno
      HiSense 55A7500F won't obbey to remote after power on
      by edugimeno
      Hi! I have this TV set that does the following:
      1) I press the red power button on the remote
      2) The TV turns on normally
      3) After that it won't take any other command from the remote, neither power off, volume, channel, NOTHING
      4) We need to either pull the main cable or use the built in button at the bottom to select funcion OFF
      Then after it's off, it would again accept the TURN ON from the remote and same again
      BUT:
      -The remote does show the correct IR beam while observed thru a phone camera
      -The TV works fine while using the MiRemote...
      03-14-2023, 11:22 AM
