can i replace on amp a mkp capacitor with mkt the same mf and voltage?
mkp to mkt
Re: mkp to mkt
"mkp" is metallized polypropylene, while "mkt" is metallized polyester. The two dielectric materials do have differing properties, so interchangeability depends on whether the circuit or the amplifier needs polypropylene capacitors or not. My inclination would be to replace with whatever was used originally, but whether that is practical for you there in Greece, I do not know.
My guess is that if you replaced mkp with mkt the sound quality of the amp might be affected. Whether enough to be audible even to someone with "golden ears", I do not know.PeteS in CA
Re: mkp to mkt
It's still a somewhat complex question. If the part is in a compensation network for the control loop, substituting may be OK. If it's in a snubber network or filtering for a PFC circuit, I would recommend against substituting.PeteS in CA
****************************Comment
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
Channel: General Capacitor Questions & Issues
I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
What is your advice/opinion on whether or not on old(er)...-
by bembenoI have to replace Io lenovo it 8227E so i want to know will it need to write ec firmware...10-22-2025, 12:04 AM
by javieromexHi, do you know what component this chip refers to? I need to replace it....
by GRrHaGHi, I try to replace a VRM Alpha & Omega on a GIGABYTE 3080 TI Eagle,
marking BKU0 but i can't identify part number for buy it
Someone can help me ?
do you know here i can find Sch and brd file for this card ?... - Loading...
