mkp to mkt
    mkp to mkt
    can i replace on amp a mkp capacitor with mkt the same mf and voltage?
    Re: mkp to mkt
    "mkp" is metallized polypropylene, while "mkt" is metallized polyester. The two dielectric materials do have differing properties, so interchangeability depends on whether the circuit or the amplifier needs polypropylene capacitors or not. My inclination would be to replace with whatever was used originally, but whether that is practical for you there in Greece, I do not know.
    My guess is that if you replaced mkp with mkt the sound quality of the amp might be affected. Whether enough to be audible even to someone with "golden ears", I do not know.
    PeteS in CA
      Re: mkp to mkt
      Simple answer is no don't do it, you can but not recommended.
        Re: mkp to mkt
        the caps is not on audio cirquit it is on power supply.
          Re: mkp to mkt
          It's still a somewhat complex question. If the part is in a compensation network for the control loop, substituting may be OK. If it's in a snubber network or filtering for a PFC circuit, I would recommend against substituting.
          PeteS in CA
