Solid Caps and Blowing
  • andyasselin
    • Jan 2009
    • 14
    Hi is possable for solid caps to blow bottom of caps? i was look some on video card bottom look they push down not flat
    every other solid cap i see has had flat blottoms i seen lot of one that have vent out the top
    The Card was bfg not sure brand of caps ono it
  • kaniki
    • 514
    Re: Solid Caps and Blowing
    I know i have seen regular caps that have, not sure about the solid ones but a good possibility.
    • c_hegge
      • Sep 2009
      • 5219
      I've seen pictures of solid caps exploding before, although I'm not sure how common it is.
      • andyasselin
        • Jan 2009
        • 14
        Well not sure i don,nt have card but to me they look diffent that any other i seen
        they diffently look like pop out bottom i shound have grab a picturess of it
        i test every other compent in the system
        maybe it just be bfg but all solid cap i seen are solder flat to board this one has space in between cap and board i grab a few diffent card mainboard and none of them look like this
        yes i seen pictures on net of solid one too
        they are solid state cap or every call them new inproved ones
        • andyasselin
          • Jan 2009
          • 14
          Have any you seen them not be mount flat on board ?
          i look many diffent card pictures i never seen any that had gap between board and they are the oringal caps
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            post pics.
            bet they say fz on them.not polys.
            polys can explode in case of severe abuse.
            • andyasselin
              • Jan 2009
              • 14
              I wound if had card am not at shop plus guy grab his machine
              it was bfg 9800gt wound any idea type cap it wound have?
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Sacon FZ and some others.
                Mann-Made Global Warming.
                - Dr Seuss
                • madscientist750
                  Replacing electrolytic caps by solid caps on old motherboards
                  by madscientist750
                  I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                  I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                  I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                  10-19-2025, 06:10 AM
                  by momaka
                  03-12-2025, 03:42 PM
                • eryjus
                  by eryjus
                  05-10-2023, 11:21 AM
                • Paxman_Swede
                  by Paxman_Swede
                  Hello!
                  01-14-2025, 09:51 AM
                • captain150
                  by captain150
                  03-16-2025, 07:34 PM
