Cheap recapping
  • Rainbow
    • Aug 2005
    • 1371
    Cheap recapping
    Here in Slovakia, the high-quality caps are almost unavailable. Maybe they can be ordered through some vendor, but the price would be too high. So I'm using regular (non-low-esr) capacitors for 85 degrees - so I can keep the price of repair low enough. I order a bag of 2200uF/16V (100 pieces for about $14) and 1000uF (100 pieces for about $4) capacitors with correct dimensions and recap with that. If the caps on board are different values, I check which caps are parallel and approximate the capacitance using the two values.
    So far, all repairs except one were successful (board working without any stability problems) and noone came back that the board died again (the oldest recapping done more than 2 years ago). I know that these cheap caps are worse than the high-quality ones. But there are better than the crap that many motherboard manufacturers use. A board recapped like this might work fine for a couple of years - better than throw it away.
  • Chris1992
    • Apr 2005
    • 561
    Re: Cheap recapping
    IN that case, you're really lucky. More often thn not, the non-low-esr caps cause most symptoms of bad caps.
    The great capacitor showdown!
    • Rainbow
      • Aug 2005
      • 1371
      Re: Cheap recapping
      Some manufacturers (e.g. ECS/PC Chips) use low-esr caps (G-Luxon LZ series) only for CPU power, all other caps are standard 105 degrees G-Luxon SM. I've read somewhere that these might be worse than 85 degree ones because they have higher ESR.
      My first recapped board was a 486 board 2 years ago (the old caps were not bulging but some of them were mechanically damaged) that runs continuously 24/7 since then in router (yes, there are no switching regulators there so there should be no problem). The second one is Abit BX133-RAID for a friend which works too since then - he came about a year later to recap the rest of 1000uF that were not replaced because they looked good - but they were not, they just died later.
      • Chris1992
        • Apr 2005
        • 561
        Re: Cheap recapping
        Huh. Weird. But my ECS K7SEM uses Teapo for VRM and G-Luxon elsewhere. Will check to see what series they are once I can get the board out of the system. What series can be green G-Luxon?
        • Rainbow
          • Aug 2005
          • 1371
          Re: Cheap recapping
          I've seen green (LZ) and black (SM) G-Luxons on ECS/PC Chips boards (like P6VXAT, P6IPAT, K7S5A).
          I remember that I read somewhere that some cheap board had non-low-ESR caps everywhere - but I really don't know where and if it's true. Haven't seen this personally.
          • Chris1992
            • Apr 2005
            • 561
            Re: Cheap recapping
            Ok then, my board has LZ for AGP power and SM elsewhere.
            • Newbie2
              • Sep 2005
              • 885
              Re: Cheap recapping
              One time I used non-low-ESR caps on a QDI Super Socket 7 board to replace the bad DST caps on the board and then the system would always freeze in Windows after the non-low-ESR recapping. I replaced the non-low-ESR caps with Nichicon low-ESR caps and the board would only be stable with a mere 64MB of RAM. I learned something after that. Do not use non-low-ESR capacitors for recapping. Use only suitable low-ESR caps from a good brand. Only use non-low-ESR caps if high-quality low-ESR caps are unavailable or too expensive. Rainbow had good luck with non-low-ESR recapping while I had bad luck.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • Rainbow
                • Aug 2005
                • 1371
                Re: Cheap recapping
                Some boards might be more sensitive to capacitor quality. Also some non-low-ESR caps might be better than some other.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  Re: Cheap recapping
                  and some standard parts from a reputable mfr. may be better than the junk the board was built with!
                  • Newbie2
                    • Sep 2005
                    • 885
                    Re: Cheap recapping
                    I think my old QDI board I play with is very sensitive to the capacitors. I guess it only accepts low-ESR caps. kc8adu is right about that good non-low-ESR caps from a good manufacturer would be better than low-ESR caps from a bad manufacturer. For example, non-low-ESR Rubycons are better than low-ESR G-Luxons in quality!
                    My gaming PC:
                    • proxneo
                      Recapping Sony ICF-SW55 - verifying cap values
                      by proxneo
                      Dear reader
                      I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                      At the moment, I have selected replacements based on the following list of values:
                      3 x 470uF 10VDC
                      3 x 4.7uF 35VDC
                      4 x 47uF 50VDC
                      8 x 22uF 6.3 VDC
                      1 x 220uF 6.3VDC
                      5 x 100uF 6.3VDC
                      Which...
                      06-21-2023, 12:38 AM
                    • H34TO
                      ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                      by H34TO
                      Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                      06-17-2025, 07:17 AM
                    • evilkitty
                      When your mom is complaining about her new cheap lights
                      by evilkitty
                      My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                      well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                      lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                      07-23-2024, 01:27 PM
                    • aaronkatrini
                      by aaronkatrini
                      - Autorange
                      - DC volts up to 30V
                      - Accurate Resistance
                      - Diode test (Beep mode)
                      - Frequency up to 200MHz
                      - Capacitanze up to 5000uF
                      - as cheap as possible
                      05-06-2024, 09:54 AM
                    • Dan81
                      The Cheap Duo - Two SiS machines
                      by Dan81
                      Just as the title states. Two cheap SiS machines, surprisingly stable.
                      What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                      The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                      CPU - P3 1100MHz Coppermine...
                      04-16-2022, 12:28 PM
