Capacitor naming in notebook schematics
  • yellobello
    • Apr 2021
    • germany
    I need to replace a 0402 ceramic cap that mysteriously vanished from existence when I was reflowing some ram chips on a Lenovo mainboard.
    So, since I have the schematics I thought it would be easy to locate the missing cap and get a new one, but Lenovo has some (for me) unusual naming scheme for their caps. It is labeled as SCD047U6D3V1KX-GP
    The schematics even give an example of the naming scheme as seen in the pic,
    but I am not sure which value they mean. maybe the D means decimal? so that would be a .047uF or 47nF / 6.3V 0402 X5R then?
    I do not want to make another stupid mistake
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: Capacitor naming in notebook schematics
    more arbitrary names by lenovo or whoever OEMs...
    Looks like you probably got it right, at least assuming things can be extrapolated: SMT ceramic 0.047uF±10%, 6.3V, 0201 sized most likely, X7R/X5R
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Agent24
      Dick Smith Q-1760 linear power supply filter capacitor question
      by Agent24
      I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
      It has at least one problem.
      The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
      I have already ordered a replacement potentiometer, so that's not an issue.
      Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
      All are CapXon...
      10-21-2025, 05:39 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • kbjunkie
      HP Z800 Workstation - Schematics or help identifying capacitor / component value
      by kbjunkie
      My first post here for help - and I'm hoping someone here can help me..
      My Z800 dual Xeon workstation has stopped posting. Just high fan spin on power up. I did a little digging about and found some electrolytic caps that were bulging and had leaked onto the board. I've replaced those and then discovered the remnants of what looked like another cap (SMD) had disintegrated on the board in the same part of the circuit. It looked like a cap but I have no way of knowing for sure, or what value it may have been as there was nothing left of it.
      I...
      09-04-2023, 07:06 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
