I'm gonna recap my ol' xbox 360 mobo however i'm a bit curious about the caps in your store.
These are the caps i need..
Rubycon 1500uF 16v MCZ
Rubycon 820uF 6.3v MFZ
Nichicon 220uF 10v HE(M)
Well i see you got the 1500uF one, however the 820uF you got is 'MCZ' while i need 'MFZ', is there any difference between them? I am by no means an expert in the field and the only difference i could find is that the 'MCZ' is 12mm in height and 'MFZ' is 24mm in height..
I'm also curious if it would be safe (would it even work?) to use a Rubycon 220uF 16v YXA instead of a Nichicon 220uF 10v HE(M)?
Thanks in advance!
Thanks in advance!
