bad caps or not on fried P4VMM2?
  • ac.r
    • Aug 2005
    • 4
    I should preface this by saying that the issue has been resolved and it's really only of academic interest of this point, I'm just curious as to whether my problem was caused by bad caps, or something else. If the capacitors are the problem, I can post photos and capacitor brand names.
    The motherboard is (was) an ECS P4VMM2. It had been working fine in a heavily-used desktop PC for almost 3 years. I'm not sure of the brand of power supply I used but I can check in a few days.
    Things started getting a little funny when I could hear the CPU working (actually it may not have been the CPU but definately not the hard drive or anything else normally audible): scrolling a webpage or whatever would make a sort of high-pitched hissing sound. This got worse over a couple weeks until there was an audible whine accompanying it, but I didn't think it was a problem. Then one day, halfway through loading Windows the computer shuts off completely. Prior to this there had been no crashes or errors, everything was totally stable. I restart it and it shuts off within a few seconds. So I open it up and some of the capacitors are visibly bloated and hot to the touch when it's turned on (but no electrolyte leakage). Even with everything disconnected it still shuts off- so I figure the motherboard is shot, maybe power supply too. While I'm reasonably skilled with electronics and probably could replace the capacitors, it's not that great of a motherboard so I'd rather just replace it.
    I take it to a computer store and tell them to replace the motherboard and test the power supply (not quite 1337 enough to do it myself). I get a call back saying that the motherboard tested fine but the power supply and hard drive are "bad". The hard drive was okay- it slaved in another computer without a problem (though possibly some Windows data got corrupted and it wouldn't boot- no way to tell at this point) and the motherboard isn't fixed- with the new power supply installed it doesn't shut off now but it still makes the same noise, worse than ever, and the capacitors still get very hot.
    So anyway after immense frustrations I backup the data, take it to less incompetant computer store that recognized the problem, and get it back with a new motherboard and wiped hard drive with a fresh Windows installation- everything's okay now.
    What I'm wondering, though, is what caused the problem. The capacitors were definately bad but did they fail on their own or was it caused by the power supply or something else? Consider the following:
    The motherboard worked fine for almost 3 years before failure.
    It failed by shutting off suddenly, which was "fixed" by replacing the power supply.
    There were no gradually worsening errors or crashes...
    But there *was* a gradually worsening high-pitched squeal (from what?).
    And the capacitors were hot to the touch- do capacitors with bad electrolyte die due to overheating?
    Like I said at the beginning, this doesn't really matter now, but I would like to know, just to appease my curiosity. Next time I'm home I can report back with the brand of power supply/capacitors and photos.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: bad caps or not on fried P4VMM2?
    Yes, bad capacitors.
    --Randy
    • PeteS in CA
      • Aug 2005
      • 3581
      • USA, Unsure of Planet
      Maybe check the CPU fan, too? The squealing may be that or the VRMs may be oscillating due to bad caps (the control loop has compensation for the ESR, and if it's way high, the loop couldoscillate).
      PeteS in CA
      • MD Willington
        • Sep 2004
        • 702
        Luxon or OST?
        Ya'll think us folk from the country's real funny-like, dontcha?
        The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
        • ac.r
          • Aug 2005
          • 4
          It wasn't the CPU fan making the sound, I'm still using that on the new motherboard and it's fine. The more I think about it, it does seem like bad capacitors, I was just wondering because it doesn't seem like the typical mode of failure.
          • ac.r
            • Aug 2005
            • 4
            Okay, just checked, the blown caps are all I.Q brand, the smaller capacitors (1500 uF or less) are G-LUXON but they're "okay", or at least haven't failed yet. I can post photos soon-ish.
            I looked in the power supply too, it's a SkyHawk SH300A8H. The capacitors are CapXon and Jun Fu (only a few smaller ones). Physically it seems okay but I'll assume it's bad because replacing it fixed the shut-off problem (though it may be that the newer one just supplies more current before the overload circuit kicks in). I'm not really going to try to test further because, like the motherboard, I'm not going to miss it anyway.
            • ac.r
              • Aug 2005
              • 4
              Got photos, showing the bad OST I.Q capacitors as well as some of the "good" G-LUXON ones. They're not particularly exciting as none of the caps have leaked or vented, and actually they seem considerably less bloated than they were initially (hydrogen gas readsorbed?).
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • Bonaventure Vigil
                Variable DC Power Supply cannot boot motherboard
                by Bonaventure Vigil
                Hi there,
                Guys anyone here can help me. During troubleshoot the motherboard, my 1st and new psu unable to boot the motherboard. Even though i set the 20V, my old Compaq CQ42 motherboard had the led white light at charging port. When press on button, the led blinking to red and gone back to white state. But i change the oem hp compaq adapter which is i measure 19.45V. Using that can boot the motherboard and fan spinning. Then i reconnect psu and tried set the 19.45V, still blinking red. Anyone know what happen? Is it psu not compatible? All is check and voltage is there....
                10-17-2024, 12:16 AM
              • dragon3x
                After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                by dragon3x
                Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                power on.
                Here are some examples :
                (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                switching supply area).
                (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                than 6.3 V.)
                1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                I replaced capacitors with aluminum-polymer.
                3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                03-21-2025, 02:46 PM
              • varkatope
                Need help identifying capacitors on an MSI MS6163 ver 1. motherboard
                by varkatope
                Hey there, retro fans.
                I have an MS6163 version 1 board I'm trying to repair which was obviously used as a donor because it's missing a few parts, mostly capacitors. There are few high quality images online that would allow me to read the capacitor values (bad angle, blurry photos). I thiiiink I've figured out most of the values for the missing ones except for one in particular, number C210, which is in the bottom-left of the attached photo. Could someone with this board be so kind as to take a look at theirs and tell me the capacitance and voltage values of all the highlighted missing...
                12-15-2024, 09:48 AM
