or is it: precapping your psu?
  • cap noob duh
    • Jan 2010
    • 28
    What is it with psu folks?
    Don't they know they have the most important job? the foundation on which the p.c. stands?
    atleast now I understand and support Dell in having a mobo that does its own psu checks.
    who can really have a mobo that's balanced and stable while,
    there are psu's making popcorn.
    so, my GA-7VT600-L dies, I get Dell GX280; then I find out about caps...
    GA-... had decent caps:
    - HM @1000uf & @1500uf, KZG @3300uf, WX(Vcc) @1200uf
    its vantec 420A psu that I bought:
    - Fujiyuyu (whatever)
    - obviously cause of problems, the 2 WX's look fine.(protected through MOSFETs?)
    (my voltage readings were getting worse, didn't understand why, back then.)
    Dell has decent caps, still:
    - HN, ZL, MCZ, MBZ, FL(Vcc? a bunch in a line in 2 places)
    (can't find FL's specs, has panasonic 'M', may need ditching.)
    its Dell psu (came with):
    - Ltec
    note, on larger sized caps:
    mobo's: 20 to 60, and decent ones;
    psu's: 8 to 12, and cheap crap. Time for a rebellion.
  • cap noob duh
    • Jan 2010
    • 28
    Re: or is it: precapping your psu?
    hmm ok, change bad-brand caps ASAP, ok.
    what about 85c temp rating caps, ASAP too?
    - these are around cpu.
    • c_hegge
      • Sep 2009
      • 5219
      85*C around the CPU?? That's unheard of. the CPU caps are always 105*C
      • cap noob duh
        • Jan 2010
        • 28
        so change them, ty.
        • cap noob duh
          • Jan 2010
          • 28
          and what about away from cpu?
          • etnietering
            • Apr 2009
            • 379
            If the case is well ventilated, 85 degree caps elsewhere on the motherboard will probably be alright. But, if everything runs hot, they're from a known bad brand, or you have few/small/low airflow fans, you should upgrade them to 105 degree caps from a known good manufacturer.
            • cap noob duh
              • Jan 2010
              • 28
              ty
              • cap noob duh
                • Jan 2010
                • 28
                the 85c cap is on the top right corner of cpu, and
                is beside the cpu_fan plug.
                220 uf @ 16v 6mm 85c (12v fan)
                - same as the 5 identical ones around the usb's.
                (but they are closer to the pci-e than the cpu, and lower down.)
