Capacitors
  • NESTIAM
    • Jan 2010
    Capacitors
    I have a Dell 8400 bought in about 2004 with Nichicon capacitors HN(M).
    There are 6 of these that show bulges and one with a light brown substance
    appearing on top. I would like to try and replace these however they do not
    match up to any of the instock Rubycon or Samxon capacitors.
    Mine are as follows:
    2200uf 6.3V Height 16 mm Diameter 10mm
    1000uf 10V Height 14 mm Diameter 10mm
    I measured these from the motherboard to the top of the cases. Is this
    the proper way to determine height?
    Is the height and diameter stamped on the case any place?
    Do the above measurements seem like legitament sizes?
  • 370forlife
    Large Marge
    • Aug 2008
    • 3112
    Re: Capacitors
    https://www.badcaps.net/store/produc...products_id=33
    https://www.badcaps.net/store/produc...products_id=47
    Those should work just fine. 10mm sounds right
    • kaniki
      • 514
      Re: Capacitors
      It is best to use the same size around that is in there because the leads and the way it fits will usually be the same doing it that way, but the height is not usually a problem. As long as the uf size and volts match up and fit, then if the replacement is bigger or smaller in height, then that is fine, just as long as it does not hit anything.
      • quickname
        Cyberpower 1500AVR UPS repair
        by quickname
        I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
        I decided to verify that the batteries were...
        11-12-2023, 09:57 AM
      • dragon3x
        by dragon3x
        power on.
        Here are some examples :
        switching supply area).
        than 6.3 V.)
        03-21-2025, 02:46 PM
      • ssl6
        MSI K7T266 Pro (Ver. 1.0)
        by ssl6
        Hey Everyone,
        Long time lurker, but I think this is my first time posting.
        Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
        I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
        11-09-2023, 01:00 PM
      • slybunda
        AA and AAA battery charger capacitors?
        by slybunda
        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
        it has inside:
        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
        2 x 470uf 16v LZ105c branded as G.Luxon
        not heard of these brands are they any good?
        iv attached photos of the charger and the board inside for an idea on the type of...
        12-24-2023, 04:41 AM
        After all of...
        07-13-2024, 08:14 PM
