I bought this capacitor kit and I used a 100uF across an input voltage of 19V (using a laptop power supply). Within about a second or so after connecting power, the cap gave up the smoke.
I've never worked with these types of caps before, I usually use the traditional black electrolytic caps.
Is there something about these caps that make them more sensitive or is there something I should know about this type that might be different from the standard type I normally use?
