Fake Nichicon PS series?
  • s675
    • Sep 2015
    • 35
    3 or 4 years ago I purchased a TDA7293 amplifier board from eBay.
    I have never used it, but I looked at at and noticed that the large filter caps are ostensibly Nichicon PS(M) 2200uf 50v. They measure around 16x26mm (15x25mm?).
    I was surprised that a cheap board would come with capacitors like these. The small ones on the rest of the board are various cheap brands.
    This is more curiosity than anything else, but I wondered whether they are fake. In particular I noticed the difference in heat-shrink at the top, and the slightly different looking vents. Is this disparity in appearance normal?
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Fake Nichicon PS series?
    The stamps, don't even look like they were manufactured by Nichicon.
    I'm calling foul!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      You better believe they're fake...
      Pull em- they'll have flat or bullseye bungs.
      Seen on lots of cheep kits/modules, on banggood, icstation, ebay, etc.
      "Perception management"- kitmakers' items stand out this way. "Japanese caps are better," amiright?
      It's an earlier module you got. The stock pix still show fakes, but they're shipping now with fakes in their natural appearance. Got some BG kits here with "BH," "JWCO," "changX/chongX," which is what those "Nichicons" really are. Such low grade trash they don't even bother to get the colors right.
      Real PS are brown with white printing, like PWs; not just fakery but half-ass fakery, like they're not even trying. Again, all about perception.
      2200u 50v PS are 18x35.5mm.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • PeteS in CA
        • Aug 2005
        • 3586
        • USA, Unsure of Planet
        Unless Nichicon changed the color of their sleeving for the PS series in the past 10 years, the black sleeving is the wrong color. Should be brown.
        PeteS in CA
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          100% phony.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • kaboom
            "Oh, Grouchy!"
            • Jan 2011
            • 2507
            Originally posted by Topcat
            100% phony.
            Well... aren't we being modest here?
            Those are at least 110% phony!
            To the OP:
            They seem small for 2200/50v and may in fact be several voltage ratings below their "sticker value."
            They could be as low as 1000u/25v, so beware of applying what appears to be rated voltage.
            There were some BG reviews of amplifier kits stating the "25V" caps leaked or oozed below their rating.
            By stark comparison, recently purchased late-80s NOS 10,000u/25v Panasonic snap-ins had leakage under half a milliamp after ~3mins at 25v thru a 10k resistor.
            EOL it...
            • s675
              • Sep 2015
              • 35
              Thanks all!
              I took them off and yep, bullseye bung.
              Tested at 2112uf on my cheap meter, so at least that's normal.
              The other caps on the board are:
              2x Jwco 47uf 50v 105c (12.5x5mm)
              2x CZF 10uf 50v 105c (12x4mm)
              I suppose that they are also not actually 50v?
              Also of note is that the SEP KBL608 regulator looks like it has been re-used.
              The one thing that actually seems OK is the TDA7293 itself. Alcohol doesn't take the markings off.
              I've attached some pictures.
              • s675
                • Sep 2015
                • 35
                I should say the SEP KBL608 rectifier.
                • jayjr1105
                  • 281
                  What was ESR? The fakest of fake caps will still be around the correct capacitance.
                  Ryzen 3600x
                  16GB Patriot 3600MHz
                  MSI B450 Gaming Plus
                  MSI Air Boost Vega 56
                  Acer 32" 1440P Freesync
                  Rosewill Capstone 750W
                  Hakko FX-888D Station
                  FX-8802 Iron
                  MG Chem .8mm 63/37 RA 2.2%
                    master hoarder
                    • May 2008
                    • 12175
                    LOL.
                    I bought one of those TDA7293 boards recently as well for GP speaker tests and whatnot (but may end up using it in a small subwoofer that has a control board more complex than a space station.)
                    At least mine came with truly genuine ChongX caps, though. Series? - They don't say. But vent is misspelled as "VEHT". Technically speaking, the "H" is the correct Cyrillic substitute for "N" in the Latin alphabet... but I digress.
                    As for some of the smaller caps on my board - JWCO brand, like yours. I'm not surprised, of course, because I paid absolute bottom-dollar for the board I found. (HINT: when you find a kit that you like on eBay, look for listings of the same kit in the "similar items" area. Eventually, you should see lower and lower prices. Given that all of these use the same questionable parts, I wouldn't pay more money for any reason. Grab one for the cheapest possible... or as I like to do, always grab two in case one is DOA... and hope for the best. )
                    If they are miniaturized 85C GP caps, they might (optimistically) be capable of handling 50V.
                    Just as a comparison here, I do have genuine Nichicon RS, 50V, 2200 uF caps attached on a Sony CRT TV audio processor (AK) board (I don't recall which model Sony it came from, but board p/n is 1-674-082-31 if anyone wants to know for whatever reason.) These Nichicon caps measure 18x25 mm (datasheet says they should be 20x25, but these could be custom-order for Sony), are rated for only 85C, and have a black sleeve with white text. (On that note, I wonder if that's what your counterfeit Nichicons were trying to impersonate, lol.)
                    With my ChongX being slightly taller at 30 mm (but only 16 mm dia.), I could give them benefit of the doubt that they may stand up to their 50V rating. But would I? IDK, probably not.
                    That's good.
                    Hopefully it came out of some junk legit power adapter. Otherwise, if new, you never know how legit the part is and whether it will do its ratings.
                    It could still be a counterfeit or factory reject. Give it full max abuse according to the datasheet and you'll probably know.
                    FWIW, though, these boards are still pretty cool to play around with for just a few bucks. Just don't expect miracles out of them, obviously. At the same time, also expect there to be some chance of magic smoke, regardless of how you treat them.
                    I think 107% is more accurate.
                    Ask Garage54 why.
                    It's a Russian YT channel for silly car mods^
                    O.o
                    Now you're tempting me here to remove mine and give them full voltage.
                    No surprise.
                    Good Japanese caps are good, even at 20-30 years age. Sure there were a few problematic series. But overall, I'd use an old/NOS Japanese cap any day over China garbage that doesn't even have the courage to stand under its own brand name (and tried to counterfeit others.)
                    • s675
                      • Sep 2015
                      • 35
                      0.14 ohm ESR, 0.3% Vloss. I suppose that ESR is OK considering the accuracy of the meter. At least they are "real".
                      I read that scam emails purposely misspell words to ward off those who are paying attention. Though I suppose it's more likely that they simply don't know or care
                      I have a bag full of various values of small capacitors from AliExpress. Almost every value is a different brand. I have Jwco, HuaHong, JNC, ChangX, JEC, JackCon, Chong, MHC, HongKai, Fujicon and United.
                      I see that Fujicon is especially well-known on this forum. I wonder how many of the others are marques of the same manufacturer(s).
                      I think with any component of questionable provenance/veracity it's a good idea to significantly de-rate it, if using it at all. Though I'd always prefer stuff from reputable sources.
                      Good point! Would be funny if the original power adapter used fakes/rejects though.
                      Nice to have some excitement!
                      • ChaosLegionnaire
                        HC Overclocker
                        • Jul 2012
                        • 3266
                        • Singapore
                        lol so besides speaking and writing broken english, the chinese have also written broken cyrillic as well! lmao!! well the russians will be pissed at their chinese comrades for that lol!!
                        yea its nice to get some excitement in our boring lives to keep us on our toes and to make life worth living lol! dont let fear dominate you. dont let fear stop u from living your life to the fullest! oops... not the vip room... i'll stop now.
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          "H" is just to the northwest of "N" on a "Q W E R T Y" keyboard, so it possibly was a fat-fingering, LOL!
                          Arc A770 16 GB
                          • DrewPhillips
                            Capacitor Diarrhea - Nichicon PL Series
                            by DrewPhillips
                            Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
                            The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
                            03-02-2025, 10:18 PM
                          • chth96
                            Is there datasheet for nichicon LXJ series?
                            by chth96
                            I want to calculate capacitor ESR referring to below guide.
                            https://forum.digikey.com/t/calculat...-from-tan/2633
                            I must find out dissipation factor(Tan(δ)) for nichicon lxj series(6.3v 1500uf,25v 1000uf ,10v 2200uf)
                            I finally found out datasheet which has all series of nichicon capacitor.But unfortunately, It removed old nichicon capacitor.
                            Is there anyone who still has old nichicon datasheet which has information of LXJ series?
                            11-20-2022, 08:11 AM
                          • chth96
                            Is there any datasheet for nichicon RT(M) series?
                            by chth96
                            A few days ago,I destroyed one of my japanese retro game console by pluging it to 220v outlet.
                            https://www.badcaps.net/forum/troubl...e-been-blew-up
                            and I finally fixed​ this retro game console by soldering varistor and glass fuse.
                            But I noticed that When I measure voltage of PSU's 5pin connector, it is 8.80-9.07v, 5.13v,3.40-3.48v,GND,GND instead of its rated voltage of 9v 5v 3v GND GND.
                            I have spare console...
                            11-28-2023, 03:36 AM
                            ASUS Pro Series D320MT-I564001774 Pro Series i5-6400 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320MT-I564001774 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320MT-I564001774 boardview and Pro Series D320MT-I564001774 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 03:28 PM
                            ASUS Pro Series D320SF-I564000134 Pro Series i5-6400 Specification for Upgrade or Repair
                            This specification for the ASUS Pro Series D320SF-I564000134 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pro Series D320SF-I564000134 boardview and Pro Series D320SF-I564000134 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
