Blown cap
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Blown cap
    Does this capacitor look like it's leaked or blown?
    • 31131
    Re: Blown cap
    yes, but usually you see the negative terminal leak first.
    • LEEDASH
      • Dec 2012
      • 481
      • Bedfordshire
      Re: Blown cap
      Might answer why the unit don't switch on,
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3264
        • Singapore
        Re: Blown cap
        interesting! its leaking gold coloured stuff? lol! might it be iron pyrite or fool's gold? rofl!
          master hoarder
          • May 2008
          • 12175
          Re: Blown cap
          That ooze almost looks like the tan/brown glue that goes conductive. But I don't see that kind of glue anywhere else on the board, so I don't think that is it. Very surprising that it is leaking out of the positive terminal. As stj said, usually they do it on the negative one. And yeah, that very likely be the reason for not getting power. Just hope nothing else has blown when that cap went.
          Also curious what brand of capacitor is that?
          • jayjr1105
            • 281
            Re: Blown cap
            Looks like a Taicon to me.
            Ryzen 3600x
            16GB Patriot 3600MHz
            MSI B450 Gaming Plus
            MSI Air Boost Vega 56
            Acer 32" 1440P Freesync
            Rosewill Capstone 750W
            Hakko FX-888D Station
            FX-8802 Iron
            MG Chem .8mm 63/37 RA 2.2%
              master hoarder
              • May 2008
              • 12175
              Re: Blown cap
              Yup, Taicon it is.
              A little surprised, though. Generally, I see them fail a lot less than other 2nd tier brand and expect them to fail less. But I suppose that doesn't mean too much when it comes to 2nd tier caps.
              • pc7fan
                • Aug 2013
                • 52
                Re: Blown cap
                Yup, Taicon it is.
                Indeed, I've also seen failed Taicon primaries. I have actually seen more failed primaries than secondary caps from them. I would say failure rate for primaries is about on par as with Samxon, especially if in APFC.
                  master hoarder
                  • May 2008
                  • 12175
                  Re: Blown cap
                  Well, APFC is a whole another story. Even good Japanese caps fail there sometimes, particularly if the manufacturer penny-pinched and used 85C -rated caps instead of 105C -rated caps... and also 400V caps instead of 420V or 450V caps. Going with 105C caps for higher rated voltage means bigger caps - which is quite necessary, because APFC puts more stress on the caps (lower ripple current than at 50/60 Hz, but at much higher frequency, so the end result is more stress on the caps than caps simply getting rectified DC straight from the line at 50/60 Hz.)
                  • cmlewis89
                    LG 47LB5DF blown power supply board
                    by cmlewis89
                    Hi folks,
                    I'm new to this forum. So my trusty 17-year-old LG 47" LCD recently died. As I was booting it up, I heard a hum followed by a loud bang, sounds of pieces flying around, and loss of power to the unit. Inspecting the PSU, I saw two obvious problems: a blown thermistor (bang + flung pieces) and a visibly bulging main cap. Inspecting as many components as I could with my Fluke MM, I diagnosed that the following components on the "hot side" of the board were also bad: one of the 2 main MOSFETs, main 8A fuse, small cap (25V 47uF) connected to main caps, and a blown...
                    09-03-2024, 07:50 PM
                  • drscoot
                    HP X360 convertible battery blown fuse error, not charging
                    by drscoot
                    HP Modelnumber: 14-dh0061nb​
                    This laptop had a shorted cap on a Vcore section. After replacement is works again. But there is still a battery issue.
                    The battery is HT03XL and with the built-in component test from HP, in the Power section, I get an error: Logic State: Calibration required (20), Charge state: Blown Fuse (42)
                    I have another same battery, also with error: Logic State: Very Weak (70), Charge state: Blown Fuse (42)
                    And a third battery TF03XL (looks identical) with error: Logic State: OK (0), Charge state: Blown Fuse (42)
                    All these 3 batteries are charging...
                    12-15-2023, 05:54 AM
                  • swerg
                    Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
                    by swerg
                    Hey everyone,
                    I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
                    I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
                    I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
                    06-06-2024, 03:39 PM
                  • MrzPdlch
                    Blown fuses on Gigabyte GTX 980TI 6GB
                    by MrzPdlch
                    Hey everyone,
                    I just went ahead and unscrewed a faulty GTX 980 TI from Gigabyte. What I found beneath the cooler was, as it seems, a common issue of that card. Two blown fuses on the bottom right corner of the card next to a MOSFET.
                    Now my question would be if there is any schematics of that card available to figure out which are the blown components so I can try and replace them together with the mosfet if needed.
                    Find some pictures of the actual GPU together with a picture of how it should look like.
                    I also wonder whther it might be a problem that there...
                    03-10-2024, 04:14 PM
                  • cheeky2
                    Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                    by cheeky2
                    This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                    I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                    Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                    06-15-2025, 05:12 AM
