Do I want Ripple Current high or low?
  • jayjr1105
    • 281
    I see this value varies within several 3300uf caps. Do you want that number low as possible? It's very high on polymer caps.
    Ryzen 3600x
    16GB Patriot 3600MHz
    MSI B450 Gaming Plus
    MSI Air Boost Vega 56
    Acer 32" 1440P Freesync
    Rosewill Capstone 750W
    Hakko FX-888D Station
    FX-8802 Iron
    MG Chem .8mm 63/37 RA 2.2%
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Do I want Ripple Current high or low?
    for capacitors, it refers to the maximum ripple current handling capacity before the capacitor goes kaput really fast. therefore, the higher the ripple current handling capacity rating, the better. there is no limit. aim for the sky. hope that clarifies it.
    • jayjr1105
      • 281
      So is there overhead with this rating? Like near a computer processor, if you replaced a capacitor with the same voltage and capacitance but went lower on ripple rating, would it be an issue? I assume it would be more of an issue in a power supply secondary side?
      Ryzen 3600x
      FX-8802 Iron
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Well, a MB has DC-DC converters on it, basically DC input power supplies. So impedance and ripple current ratings for the input and output capacitors matter.
        When you're talking about the decoupling capacitor networks for a processor, those can have current transients in the tens of amps at rates in the 100s of amps-per-microsecond. Narrowly speaking the electrolytic or polymer capacitors in the decoupling network need to be low impedance - low ESR and low ESL. But capacitors with low impedance generally have high ripple current ratings.
        PeteS in CA
        • RJARRRPCGP
          • Jul 2004
          • 6304
          3300uF @ 10 V=Are you recapping an Asus socket 462 motherboard? (CPU runs off of +5V rail on Asus socket 462 motherboards) Or an early-one? (From the T-bird era)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • bestsystem
            • May 2011
            • 59
            some of them are rated at 100KHz and some are 120Hz, i don't know why they are not measured at the same frequency?
            • jayjr1105
              • 281
              It's an XBOX. Original caps were something like 2800(mArms) and the new ones I've been replacing are 2200 and 2500 (ZLQ and UHV). I've been going with 10v lately because space permits the slightly wider cap while getting a boost on the ripple current rating.
              Ryzen 3600x
              FX-8802 Iron
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Originally posted by jayjr1105
                It's an XBOX.
                My buddy, has an XBox version 1x.
                Arc A770 16 GB
                • PeteS in CA
                  • Aug 2005
                  • 3581
                  It depends on the anticipated usage.
                  Modern low impedance and ultra-low impedance parts will be rated at 100KHz because the anticipated usage is power supply and DC-DC converter output capacitors. Switch frequencies vary, of course, but the datasheets typically have a graph that gives an idea of how a part's impedance varies with frequency.
                  120Hz rated parts tend to be general purpose or designed for bulk input capacitance for a power supply.
                  PeteS in CA
                  • chth96
                    Is it no harm to replace with capacitor without ripple current rating?
                    by chth96
                    When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                    Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                    But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                    Rubycon YK DataSheet (b...
                    04-19-2024, 05:19 AM
                    Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
                    by sam_sam_sam
                    I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
                    I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
                    I tested the battery cells there are installed right now and they are testing good with no issues that I...
                    02-04-2025, 08:08 PM
                  • DynaxSC
                    Extreme High Current & Low Voltage Short Killer ??
                    by DynaxSC
                    Hi Folks
                    I'm looking for a extreme high current short killer solution for a reasonable cost.
                    I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                    After taking off the socket, the shorts dissappear again.
                    The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                    10-15-2024, 10:13 AM
                  • quickname
                    Cyberpower 1500AVR UPS repair
                    by quickname
                    I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
                    Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
                    I decided to verify that the batteries were...
                    11-12-2023, 09:57 AM
                    Surface Mount Fuses Fundamentals Datasheet
                    TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                    TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                    10-07-2024, 06:07 AM
