1200uf vs. 1500uf
  • Roadkill203
    • Oct 2008
    • 68
    1200uf vs. 1500uf
    Hi everyone, here's my dillemma:
    I have an Abit NF7-S V2.0 motherboard that I'm trying to resurrect after it vented some caps. My experiance with replacing caps is moderate; by far I'm not an expert, but I've done a few boards that are still running until this day.
    The motherboard has five 3300uf 6.3v caps right by the processor (Socket A), three of which are bulged and vented, then it has four 1200uf 16v caps in a row by the back panel connectors. I want to replace all of the caps in these areas. I'm gonna order the 3300uf caps, but I do have a bunch of 1500uf 16v Rubycons (NOS)- would these be a suitable replacement for the 1200uf caps, or should I stick with the 1200uf caps and order them along with the 3300uf caps?
    Also, are there any other issues with this board (as far as caps are concerned) that I should be aware of? I'm trying to keep this system alive (Athlon XP 3200 with the Barton Core, ASUS AH 4650 AGP8x 1 Gig DDR2 video card, three gigs of Kingston PC 3200 memory, Rosewill Xtreme RX950-D-B 950 watt power supply) - it's served me well over the years, never a burp until this caps issue! Besides, it would be too expensive to upgrade the board, processor, memory, and video card at this time for me.
    I've been looking on Ebay for a good Socket A board, but no luck. I used to own an Epox 8RDA6+PRO with the six SATA ports - loved that board! It died one day with no warning. It just never POSTed again. I tried replacing the BIOS chip, but nothing. The lights would come on, it would post an FF code, then go off in a couple of seconds. I replaced everything (power supply, processor, memory, video card) with 'known-goods', but it was still the same. Oh well...
    Any and all comments/help would be appreciated! Thanks!
  • c_hegge
    • Sep 2009
    • 5219
    Re: 1200uf vs. 1500uf
    You need to make sure you get the appropriate series to replace the caps. What brand/series are the originals?
    You could probably get away with replacing 1200uF caps with 1500uF, although if it was my motherboard, I would be ordering 1200uF caps with the others.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      what brand/series are the originals and replacements?
      • Roadkill203
        • Oct 2008
        • 68
        The 3300s that vented are all Rubycon MBZ, code T0345. The 1200s are all Rubycon ZL, code T0411. The 1500s that I already have are Rubycon MBZ, code T0343.
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16956
          If the replacements are similar in ESR specs, they'll be fine. I use 1500uF 16v MCZ's in place of 1200uF 16v caps all the time, never had an issue.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • c_hegge
            • Sep 2009
            • 5219
            Are you sure that your PSU is OK and that the computer is running cool? Rubycon caps never fail unless they are overheated or the voltage goes too high.
            As for replacment series, use Rubycon MBZ. MCZ would work too but they have a lower endurance lifetime (ie. they may not last as long). You could also use polymer (solid) caps as they have a much better endurance lifetime than electrolytics and the ESR is much lower, although use about half the capacitance for the CPU VRM Caps.
            • gdement
              • Jan 2007
              • 690
              Some of the early NF7-S boards had bad caps, but yours apparently is one of the good ones. I'm surprised those caps failed.
              I'd check the Vcore with a multimeter and make sure the board isn't a CPU killer. It might have a more serious problem that blew the caps.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Perhaps cruddy PSU.
                Mann-Made Global Warming.
                - Dr Seuss
                • Roadkill203
                  • Oct 2008
                  • 68
                  The current power supply is brand new, maybe used a total of a week. The computer has a massive amount of fans and the case has pretty decent airflow, so I don't think that the computer was overheated. I upgraded the power supply recently from a Coolmax 700W power supply. It's possible that the Coolmax did the damage to the caps. I've tested everthing else on my other socket A test-motherboard (processor, video card, memory), and everything works fine, so I'm hoping that the caps were the only damage.
                  I couldn't agree with you more! I'm just wondering if the 1500s would give me any kind of benefit over the 1200s (added protection, more stability, etc.), or if I should just stick with the 1200s because that's what the motherboard was designed for. Maybe I should just leave the 1200s in there and not even touch them at all, and just replace the five 3300s...
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Using the 1500s in place of the 1200s probably wouldn't give you any benefit or do any harm.
                    • shadow
                      • Feb 2007
                      • 732
                      Agreed!
                      • Roadkill203
                        • Oct 2008
                        • 68
                        Okay, just checked and Topcat doesn't list 1200uf 16v caps, so I'm using the 1500uf 16v caps that I have and ordering the 3300uf 6.3v caps from Topcat!
                        • Roadkill203
                          • Oct 2008
                          • 68
                          **UPDATE**
                          Recapped the board, everything seems to be working well, another success story - thanks Badcaps.Net!
                            by momaka
                            03-12-2025, 03:42 PM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
                            EVGA e-GeForce 7600 GS AGP 256MD2 [256-A8-N542-T2] with bad caps - fixed
                            by momaka
                            I did it again – I had to fulfill my inner desire to fix yet another old piece of hardware. This one is actually kind of worthwhile, too – it’s an EVGA e-GeForce 7600 GS AGP video card, model P/N: 256-A8-N542-T2. With the popularity of “retro” PCs from the Win9x to XP era going up, and the diminishing supply of decent AGP cards, it is expected their prices will go up. Or is it? I bought the this video card rather on the cheap side (~$9 USD shipped to my door), because the eBay seller listed it for parts or repair (and correctly noted the bad capacitors.)
                            So, here is the...
                            06-06-2020, 04:39 PM
