High voltage Capxon LP failing issues
  • didyman
    • Jul 2006
    • 14
    Dear members! I have a blog about these craps and finally i feel the time right to post here too.
    The story and possible background is described in details in hungarian. If needed, i will translate all of them. The basics in short:
    So many FSP and OEM power supplies built around the CM6800 controller, commonly named as "green line", "Bluestorm II" and "Epsilon" suffering this. Symptoms are clear: PSU failing with low load, or even no load, buzzing noise. These are the least worries, but some of them failing with the PFC coil totally burnt without failing the PFC FETs, or even the FETs are in short. After the significant rise of these unusual problems with FSP PSUs, it's clear that the primary capacitor has some kind of faliure. But this not as straight, as these caps may show exactly good parameters with a multimeter or even an ESR meter! Only a part of them may show no capacity at all, or even very high ESR. So afterall, i decided to take a closer look inside.
    Devastating. The anode conductor has totally pulverized, some kind of corrosion is in effect and contact is loose, unstable, sometimes shows spikes have arisen.
    Collected data show these commons:
    -All Capxon LPs are affected with date 2005-2006, seems that 2006.10 is already OK
    -The affected voltage rating is 400V. 450V models seem OK, but sample is too low.
    -180uF..330uF values are surely all affected.
    -There are some of these replaced as a preventive action, showing nothing unusual in use, but disassembled and clearly affected (that makes the problem even risky)
    -No bulging, no vent
    With conjunction of some collagues, we believe that a failing manufacturing process may be the primary reason, but the use of active PFC may also helps, as with the use of active PFC, the ESR value of the primary capacitor surely gets into brighter sight.
    The blog is here: http://logout.hu/cikk/kapacitasproblemak/teljes.html
    We (the prohardver forum) have also contacted FSP about this issue and awaiting answer from them.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: High voltage Capxon LP failing issues
    seeing the same thing in apple g5 psu's and even in industrial stuff.
    on the one i autopsied the lead foils to the terminals were gone.
    • Wizard
      • Mar 2008
      • 2296
      Could be the nanosecond long too high spikes is so high or incorrect electrolyte?
      Spikes means bad design or unique to specific PF IC controller or PF circuit itself.
      Cheers, Wizard
      • didyman
        • Jul 2006
        • 14
        Cheers, Wizard
        Capxon LH series, and the Ost isn't affected, aswell younger Capxon's don't show any sign of beginning corrosion. Despite of that, CM6800 and its former L4800 counterparts have some issues regarding the PFC, maybe just requiring better qualty caps to work flawlessly.
        • moxy
          • Nov 2009
          wait until you soon lose American made
          Panasonic foil
          soon to be only capxon next year
          maybe somebody could stop that
          I hope
          • CapSwapper
            • Feb 2014
            • 69
            Capxon is GARBAGE.
              • 31015
              thanks for the reminder.
              • japlytic
                • Oct 2005
                • 2086
                When I tested my collection of 400/450V electrolytics, I found two which had no capacitance at all.
                Could it be a bad weld or electrolyte corrosion between the foil and the leads?
                  • 31015
                  open them and find out.
                  • CapSwapper
                    • Feb 2014
                    • 69
                    you have a collection of CrapXon? The only place they should be collected is in a landfill.
                      • 31015
                      DELL like capxon, i have a dead psu here that was killed by one leaking.
                      • dougg3
                        Intel DX58SO high side VRM MOSFET keeps failing
                        by dougg3
                        Hi there,
                        I have an Intel DX58SO motherboard that failed last year. One of the high side VRM MOSFETs failed shorted, and it killed my i7 980 CPU. This motherboard has a 6-phase VRM. The parts used on this motherboard's VRM are:
                        • 6 x High side MOSFET: NTMFS4841NH
                        • 6 x Low side MOSFET: NTMFS4834N
                        • 6 x Driver: ADP3121JCPZ
                        It was easy to figure out where the short was, because the bad MOSFET's gate was shorted to the drain/source too. Once I removed it, all the shorts were gone on the motherboard, and I confirmed on the removed MOSFET itself that the gate/drain/source...
                        10-17-2021, 07:39 PM
                        by momaka
                        03-15-2023, 10:17 PM
                      • jdawg99
                        LG 47LA620V Same LED Failing Back Light Issues
                        by jdawg99
                        Hi All,
                        I need some help with this one please. I am attempting a repair on the backlight. TV turns on and flashes the LG logo so stripped it down and found one faulty LED. Replaced it and tested on an LED tester and the strip was good. Put it back onto the PSU and it lasted about 20 seconds before going out again. Same LED had blown. Changed it for another type of SMD one (same voltage) and it seemed fine. Put the TV back together but it was quite dim. Noticed it was in power save mode so turned it off and the screen was bright. Left it on for half an hour only to come back to the...
                        04-23-2023, 01:04 PM
                      • tvguy12012012120
                        by tvguy12012012120
                        02-07-2025, 05:13 PM
                        KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                        by momaka
                        For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                        http://www.rmac.kingwin.com/products.../abt_650MM.asp
                        I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                        What mostly drew me into buying it is its 2x PCI-E power connectors...
                        03-29-2022, 11:34 PM
