Bios corrupted, or bad caps?
  • Smith84
    • Jun 2005
    • 7
    Hello everyone. I'm new here, and I like the site! Anyway, I have a FIC SD11 mainboard. The mainboard looks ok, no bent, buldgey or leady capacitors. However it will not POST. When I turn it on, out of the case, on the mainboard box so it's not being short circuted by the case, with a know good CPU, known good memory, and known good video card, the fans spin, but no screen. I have a little PCI card that displays BIOS codes, and so I plugged that in, and it says ED and stays there forever. I looked the code up in the booklet and it means that it says "Init floppy" I thought it odd, that the computer wouldn't post because of an unplugged floppy, so I cleared the BIOS, no effect. I plugged in a floppy, still no POST, but the error code changed to EF which means "Floppy read error". Cleared the BIOS again, no effect.
    So now I'm stumped. Why would the BIOS try to read the floppy, unless its looking for a BIOS ROM or something?!?
    BTW: The CPU gets unusually hot for only 5 minutes of on time, but it is a Slot A with no fan, just a giant heatsink. I also tried a known good ISA card, but still no vid and same codes.
    so... I am sad, that it doesn't work.
  • sulbert
    • Dec 2004
    • 59
    Re: Bios corrupted, or bad caps?
    Does the floppy LED light up?
    What happens when you put a floppy in the drive that has the BIOS image renamed to amiboot.rom on it?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      how about to flip the floppy cable over, maybe it is wrong. i had a wierd board one time that would not boot without floppy attached correctly.....sounds like something worse though.
      what is the history of the board, when did you have it posting before and what happened.
      • Smith84
        • Jun 2005
        • 7
        The LED does light up, and the cable was in there correctly. All the floppy does is the cranking sound. So I took sulbert's advice. I renamed a new BIOS to amiboot.rom and after a few more codes, POST!! I didnt know you could reflash like that, it was cool!
        Now my only question is, how would the BIOS get corrupted? Is it going to happen agian? Btw, willawake, as to your history question, the board was in operation about a year, to six months ago, when it just wouldn't come on anymore. There was no power surges, or physical abuse of the board.... Could a dead CMOS battery have anything to do with it? Prob not, but....
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          sulbert is the man YEAH!!!! GO sulbert.
          as to WHY? shit we will never know about that board...mysteries of life, call us when it happens again. but experience shows when something is up and not dealt with it will happen again.....
          i wish we could hand out tshirts but we are too low budget.....
          • Smith84
            • Jun 2005
            • 7
            Alright, cool! I'm very happy with my fixed board. Thanks, Sulbert!
            • Chris1992
              • Apr 2005
              • 561
              Good thing it works now, but FIC were known to use badcaps. What brand are the caps?
              The great capacitor showdown!
              • FalconPunch
                Surface Pro X 1876 Bios corrupted
                by FalconPunch
                Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
                Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
                08-09-2025, 03:56 AM
              • macabook
                by macabook
                🧩 Initial Issue
                07-24-2025, 02:17 PM
              • TylerHyde21
                Lenovo TD350 ThinkServer BIOS v505 Corrupted BIOS,
                by TylerHyde21
                Hello, the bios on my Lenovo TD350 ThinkServer got corrupted during a bios update, the bios restore function killed the Server.
                I need to flash the bios inside the MX25L12835F SOP8, i have already desolder the chip and solder it into my SOP8 adapter and read it with a ROM programmer.
                I use the innoextract 1.9 software to extract the bios file from the .exe file that i download from lenovo website, can you help me edit the Hex file (removing the Index part and resize the file)?
                This guy claim to have done it https://forums.lenovo.com/t5/ThinkSe...doesnt-Start-u...
                06-29-2024, 10:38 AM
              • Loli Popu
                DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 08:29 AM
              • Vesko356
                by Vesko356
                08-11-2023, 03:27 AM
