Improving CRT geometry by upgrading capacitors
  • clearchris
    • Dec 2013
    • 687
    Re: Improving CRT geometry by upgrading capacitors
    I totally agree, I fix everything I can. Unless you have some really top of the line CRT, running any modern software will be quite painful on a low-res crt.
    • Hitto
      • Apr 2019
      • 95
      • Italy
      Originally posted by clearchris
      So what's the use case for keeping a CRT running? I'm sure anyone who hangs here can find a broken LCD and make it work.
      Because the quality of the picture, its contrast, the blacks, the colours and the sharpness beats hands down the quality of any LCD I've encountered so far.
      Obtaining a perfect geometry is howewer almost impossible.
      You have to either:
      1) Restrict the picture horizontally, obtaining an almost acceptable geometry, leaving black borders on both left and right.
      2) Enlarge the picture, which exposes unlinearities on the edges of the tube, but no black borders.
      So, you have to accept a compromise.
      Apart from that, picture is outstanding and even movements on both movies and games have perfect responsiveness already at 85Hz.
      Are you running old school nintendo and want to play "duck hunt" with the orignal zapper?
      No, this is a PC CRT with Triniton tube. On CRT TVs coming with an acceptable geometry is much easier.
        master hoarder
        • May 2008
        • 12175
        Exactly!
        Well, I don't know about the sharpness of a CRT beating any LCD. In fact, CRTs are typically a lot less sharp than LCD monitors (due to pixels in CRTs not being exactly square, unlike LCDs.) But you are absolutely right about the colors, contrast, and deep blacks. Also, don't forget that CRTs do not show any tearing on a moving image, regardless if the image is v-synced or not. This is why video/moving image on a CRT running even at 60 Hz still looks more fluid than an LCD. And also why analog video looks better on a CRT than LCD... well, it's that, and the fact that CRTs have a more neutral mid-tone colors. LCDs tend to "exaggerate" colors near mid-brightness levels, and this makes compression artifacts on video (especially low-bit rate and non-HD) show a lot more.
        Indeed.
        This is why I still actually use CRTs for gaming. Many people ask me why I keep those old things until they try them out. The difference really is noticeable.
        Not really.
        Most web pages still render fine on 1024x768, and that's the resolution I still use quite frequently myself. For other software, bigger resolution may be needed to fit more stuff on the screen. Personally, though, I don't like that, because then text becomes to small to read. I like to sit fairly far from my monitors, so very larger resolutions start to bother me a lot if the text becomes too small to read. I don't like hunching over the screen to see it.
        That said, I only switch to higher resolutions when gaming... and by higher, I mean 1152x864 or 1280x960. On a CRT (especially standard 17" and 19"), those resolutions don't look grainy at all, unlike on an LCD. Very rarely, I may do 1600x1200 on my 21" CRTs, but it's rare. I rather sacrifice resolution (especially on older PCs) to gain framerate and higher refresh rate. 85 Hz on a CRT looks amazing for gaming.
        In terms of image color quality, I wouldn't say that a large "top of the line" CRT necessarily looks better. Most CRTs actually have a trade-off between contrast and screen size. For a given tube anode voltage and current, bigger screen means light output from the tube is spread over a bigger area, and that means lowered contrast. I find this to be especially true for Sony CRTs. Both of my 21" Sony's have significantly worse contrast than the 17" and 19" models from the same line. So if I want better "cinematic experience", I go for the smaller screens. On that note, I find 19" CRTs to be the best compromise between contrast and screen size.
        • Hitto
          • Apr 2019
          • 95
          • Italy
          I agree.
          Too bad that time is passing and the plastics, even with very good monitors, are both yellowing and degrading. The age of the plastic material goes the point that you have to be careful even removing screws (when removing e.g. the main board) or mounting back everything will be impossible. Faston are to be swapped to get rid of corrosion, you have to refresh most of the solder points and so on.
          And metal boxes with shielding are oftenly rusted, so restoring takes days and days and is an extremely challenging task where a single error makes everything useless.
          • clearchris
            • Dec 2013
            • 687
            The yellowing can be revesed to a large extent, see http://retr0bright.com/
            The plastics turning brittle, I'm not sure anything can be done, but it, like the yellowing might not be a one-way process.
            • Logistics
              • Apr 2007
              • 721
              How are you guys connecting to said CRT's? Are these TV's with SVGA-in's? I understand soandso was using a Trinitron monitor. But I still have a big SGI out in the container, and another Hitachi ir similar with the R, G, B, H, V BNC connector cable. Maybe I should bust these out and try some modern games on them. But what strategy would I need to get video out of something with DVI or HDMI to an analog monitor?
                • 31303
                check your DVI, there are different pin patterns,
                some output VGA aswell as digital, others are digital only and have some pins missing.
                if your lucky, you can just use a DVI to BNC cable (or to a 13W3 for the SGI monitor)
                • Hitto
                  • Apr 2019
                  • 95
                  • Italy
                  #28
                  I rely on a PCIe VGA card with direct VGA output.
                  By the way, the CRT is still working perfectly. Planning to find a bigger monitor and tune everything till the geometry is almost perfect.
                  The picture looks real, incredible. Not bad for a 2002 monitor.
                  • Hitto
                    • Apr 2019
                    • 95
                    • Italy
                    #29
                    Another picture:
                    800x600 with a $20 VGA card.
                    For people who think that CRT is outdated technology.
                    There is room for higher resolution up to 1280x1024, maybe 1600x1200 with a better video card.
                    Well, the quality maxes out at 1024x768 in terms of sharpness which is even more defined than 800x600. Capacitors which passes video signals where upgraded with very low E.S.R. capacitors and decoupling for video amplifier was "improved".
                    The most difficult task was guessing parts which needed better components and places were avoiding low E.S.R. capacitors was a better choice (e.g. quality went up when upgrading VDDA-VSSA coupling capacitor on the digital deflection IC).
                      master hoarder
                      • May 2008
                      • 12175
                      #30
                      That depends on your video card.
                      Analog output is no longer built into current-gen video cards anymore. In fact, the last (and best) nVidia video card to have analog output (through DVI-I) is the GTX 980 Ti. And for AMD, it was the R7/R9 series, I believe... though I can tell you for a fact that not all 290's come with DVI-I (like on my ASUS DCuII, where the designers simply chose not to have a DVI-I connector, despite the card GPU chip actually having a RAMDAC.)
                      Thus if you want analog output from a video card without having to use an _active_ adapter/converter, then you will need either a GTX 900-series or older video card or Radeon R7/R9 series or older. Anything newer doesn't have a RAMDAC and hence no analog output.
                      ...and another Hitachi ir similar with the R, G, B, H, V BNC connector cable.
                      You can still get BCN-VGA [D-SUB] cables on sites that sell used stuff, like eBay. In fact, I got one last year, since I have one at my uncle's house, but not one at my house, where I still have and use old CRT monitors. For $8 shipped, I got a genuine good quality used BNC-VGA cable. Beware of the cheap stuff from China. I suspect they may have cheaper shielding, which could cause ghosting or poor image at high resolutions. Or maybe they are fine, I don't know, I haven't tested them. But I am always weary of cheap stuff from China.
                      Honestly, I don't think you would be disappointed.
                      You may not be able to run the games at such high resolutions. But then again, I don't really recommend going for the highest resolution anyways. Rather, try to balance things between resolution and refresh rate. For the latter, 75 Hz minimum and 85 Hz preferable. If your rig can run the games well in excess of 85 Hz, you can even try V-sync for extra smooth experience. In general, it's almost impossible to see image tearing on a CRT. But with V-sync on, the image will look even smoother. Or you can jump up to 100 or 120 Hz for super-smooth gameplay.
                      • MORETTIGIAN
                        by MORETTIGIAN
                        Title:
                        Description:
                        Procedure performed:
                        - Removed backplate
                        - Reapplied thermal compound
                        - Reassembled card
                        09-18-2025, 12:14 PM
                      • chth96
                        by chth96
                        12-22-2023, 04:34 AM
                      • chth96
                        by chth96
                        06-02-2024, 07:31 PM
                      • dragon3x
                        by dragon3x
                        power on.
                        Here are some examples :
                        switching supply area).
                        than 6.3 V.)
                        03-21-2025, 02:46 PM
                      • chth96
                        Is it no harm to replace with capacitor without ripple current rating?
                        by chth96
                        When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                        Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                        But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                        Rubycon YK DataSheet (b...
                        04-19-2024, 05:19 AM
