SMD caps - any way of telling which is ground?
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys,
    This is pretty basic, but I've no schema for a particular board and I need to know which side of an SMD capacitor is ground. There are no ICs near by and there is a short to ground in some section of the board (so both sides of the caps are 0 ohms to ground).
    Any ideas?
  • digitalpc
    • Jun 2016
    • 305
    • .DLL
    Re: SMD caps - any way of telling which is ground?
    i use power supply setup the voltage about 3volt 0.8amper in both side and see which side
    drop more voltage is your ground, example one side of smd is 0.2v 0.8amper(this is your gorund) another side is 1.8v 0.8amper(this is your plus)
    hope u understand what i mean
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Originally posted by digitalpc
      i use power supply setup the voltage about 3volt 0.8amper in both side and see which side. drop more voltage is your ground, example one side of smd is 0.2v 0.8amper(this is your gorund) another side is 1.8v 0.8amper(this is your plus)
      yeah I was going to just do that. I guess the level of voltage drop is dependent on the type of short also. if it's a complete short then I guess there will be no significant in the difference of the voltage drops on both sides of the cap.
      I think I may just inject both sides at this stage and see what happens.
        • 31173
        what type of cap, electrolytic, tantalum?
        • JonathanAnon
          • Jul 2012
          • 457
          • Ireland
          SMDs, thought I was sorted when I had another board that was similar, but as it turns out it is different.
          I'm just injecting 4 amps in to both sides and nothing is warming up. I scaled it up from 1 amp in 0.5 amp steps.
            Might get more reply if you upload good clear pictures of what you are dealing with.
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
              Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
              by momaka
              This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
              Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
              Macron Power Technology Co. LTD.
              Let’s look at the PSU itself.
              The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
              06-02-2021, 10:05 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • howardc64
              QN75QN85BAFXZA no backlight
              by howardc64
              2+ year old TV with many (720? 65" version has 720) mini LED dimming zones. TV boots, has sound, panel picture can be seen with flashlight. No backlight. No TV model sticker on rear panel (Maybe Samsung service removed it, read below). Found the model # through the PSU and zoned LED driver board numbers.
              PSU has a click near LED output circuit at 1 second interval, sounded like the 4x barrier rectifier area. Protective pastic liner under PSU shows heat signature on the Schottky Barrier Rectifier in this circuit. Found a shorted diode (2 diode per rectifier, failed rectifier labled...
              07-03-2025, 05:08 PM
              by momaka
              03-15-2023, 10:17 PM
