E-Bay store
  • Sudum Gumudu
    • Sep 2005
    • 97
    E-Bay store
    Anyone ever buy from this guy http://cgi.ebay.com/200pc-Rubycon-10...4.c0.m14.l1262 ?
    A really good price, but could they be counterfeit?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: E-Bay store
    I don't know if they are fakes, but if I'm not wrong they are 5 years old, I think T0449 is the date code for 2004.
    Let's see more comment on them.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • Newbie2
      • Sep 2005
      • 885
      Re: E-Bay store
      Those caps on eBay are cheap, I don't think it would hurt to purchase a few and test them out on a motherboard or power supply.
      I also attached the datasheet for the series of Rubycon caps in the photo (ZLH series).
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • Sudum Gumudu
        • Sep 2005
        • 97
        Re: E-Bay store
        Ugh. Five years old. What shelf-life do they usually have? They are perfect for replacing all those 1000 uF sprinkled all over the board at PCI slots etc. There are often between 8 and 20 of them to replace at locations which doesn't require such extreme low ESR as to warrant the more expensive MBZ or MCZ, and the size is perfect (8x16).
        The only other source I know for them is Farnell, but at almost a dollar a piece, it hurts. This would be really perfect, as long as they're genuine and not too old. I might place an order for, say six, and see if they measure up.
        • Newbie2
          • Sep 2005
          • 885
          Re: E-Bay store
          I have used 4 year old capacitors on motherboards without any issue. Maybe the picture on the eBay listing is an old picture.
          At that cheap price, I'd say it's worth ordering a few and see if they last.
          My gaming PC:
          • Toasty
            • Jul 2007
            • 4171
            Re: E-Bay store
            >>...it's worth ordering a few and see if they last<<
            A few? LOL!
            200 pieces @ $45
            Send me your money!
            Toast
            veritas odium parit
            • Sudum Gumudu
              • Sep 2005
              • 97
              Re: E-Bay store
              I found an auction for 20, so I ordered them to check them out. A modest sum. We'll see. If they check out, I'll order more.
              • Gianni
                • Jul 2008
                • 681
                • Italy
                Re: E-Bay store
                I searched for info about shelf life and I found some indication on Panasonic, here attached a page (operation_storage) extracted from this document .
                On Panasonic FC datasheet you can read:
                Shelf Life
                After storage for 1000 hours at +105±2 °C with no voltage applied and then being stabilized
                at +20 °C, capacitor shall meet the limits specified in “Endurance”.(With voltage treatment)
                In another document coming from Rubycon they wrote:
                3.7. Shelf Life
                When aluminum electrolytic capacitor is stored for a
                long time without electric charge, leakage current and
                ESR may increase and capacitance may decrease.
                However such changes are very small after the storage
                around two years at room temperature for general
                capacitors or after around 6 months for low leakage
                products, so that it will not be a practical problem.
                It is explained that such changes are caused by
                chemical reaction between electrolyte and aluminum
                oxide film.
                One of the reasons why leakage current increases is
                the penetration of electrolyte into defects in the oxide
                film in lieu of the diffusion of oxygen protecting the
                defects into bulk electrolyte. If capacitor is exposed to
                high temperature atmosphere, sealing material can be
                degraded to lower sealing power and electrolyte can be
                lost due to dissipation; both of which may bring change
                in characteristics.
                I attached the document (performances) here.
                I don't know it the "voltage treatment" it is necessary on capacitor older than 2 years and if the Panasonic method is suitable with other brands.
                Ciao
                Gianni
                H. J. Brown
