Why this UPS is using 1200V IGBTs ?
  • SistMaticZ
    replied
    Re: Why this UPS is using 1200V IGBTs ?
    I hope that some one from moderation staff can solve this PM lock out issue.
  • SistMaticZ
    replied
    I send you a reply
    Thanks for your precious replies sir.
    replied
    Originally posted by SistMaticZ
    Ok sam ive sent you a message on your email.
    My adress starts with ibnou......
    You can delete your email adress from this thread.
    I send you a reply
  • SistMaticZ
    replied
  • SistMaticZ
    replied
    DOnt worry about that . Thanks sam.
    replied
    ok thats weird.
    You can send me a message at this email
    ---DELETED---
    I do not normally check this email account very often
    So please do not send a bunch of junk email I will just close this email account and get a different one
  • SistMaticZ
    replied
    ok thats weird.
    replied
    Same thing again i cant find it in the menu.
    Would be great if someone could contact topcat and tell him about my PM issue.
    i cant contact him.
    He did reply back to and you have been locked out
    I can go into any detail sorry
  • SistMaticZ
    replied
    User CP / FAQ / Community / Calendar / New Posts / Search / Quick Links / Log Out
    Look at top left hand corner of this page and you will find ( User CP ) in the top left corner then click on it
    Then another screen will pop up
    Scroll down to edit options
    Then scroll down to enable private message and select it then you should be able to send private messages
    I hope this helps
    i cant contact him.
    replied
    OK no problem .
    I hope this helps
  • SistMaticZ
    replied
    OK no problem .
    replied
    Then send a message to Top Cap about this problem
    I just sent a private message to Top Cat that you can not send private message
  • SistMaticZ
    replied
    All you have to do is respond to the PM that I send to you and I should get it
    It should have a reply button in the bottom right hand corner just hit the button and type in your reply
    Hi again. I dont have that replay button . Maybe it is somthing related to forum priviliege ?
    replied
    i dont know how to write a pm to you thats the problem. I have read your pm.
    Or
    Click on person name and Select public profile and select message then you should see a window pop up where you can type your message
  • SistMaticZ
    replied
    Originally posted by diif
    Click on a users name on the left hand side in a thread and a menu appears.
    One of the options is to send a PM.
    I dont have that option unfortunatly. maybe i should add him to my contacts.?
  • diif
    replied
  • SistMaticZ
    replied
    replied
    I send you a PM
    Look at the top right hand side of page you will private message just click on it
  • SistMaticZ
    replied
    btw how can i Pm you Sam ?
  • SistMaticZ
    replied
    ^^ exactly this.
  • rivetcity
    Panasonic TX-P42UT30E, IGBTs on the SN board
    by rivetcity
    I'm having problems with my plasma Panasonic p42txu32e. The issue started about 12 months ago.
    I have a remote controlled main outlet so whenever I turn off the TV set at night, I also switch off the whole power outlet.
    It gives me a better feeling to know I don't have 230V on any cables, so my dog can't get hurt if he gets the idea to start chewing on something.
    About 12 months ago the TV started to have the following problem: when pressing anything on the RC to get it on, the red led would go off.
    Sometimes it would turn...
    08-12-2021, 01:25 AM
  • Biruslapio
    Samsung PL42C450 plasma X-Main IGBTs
    by Biruslapio
    Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
    It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
    Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
    04-08-2022, 01:16 PM
  • tiff_lee
    Replacement 'green cap' 392J 1200V
    by tiff_lee
    I had a logitech Z506 psu go bad due some glue corroding the legs of several components and the one i'm struggling to find a replacement for is a green polyester capacitor markings 392J 1200V.
    The problem is I can't find any 3.9nF caps with a voltage rating of 1200V from any reputable retailers (plenty of 100V) , this particular cap only seems to be available from Chinese sellers which leads me to believe the rating is garbage or the cap is.
    There is a thread on this particular PSU here
    https://www.badcaps.net/forum/showthread.php?t...
    05-24-2021, 05:36 AM
  • JoWed
    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
    by JoWed
    Hello Community,
    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
    07-01-2025, 09:32 AM
  • SoulFreeze
    Inverter Charger architecture question
    by SoulFreeze
    Hello all, I have a mastervolt charger inverter I'm trying to repair, as I have no schematics I decided to trace our some of the parts to figure out the general operation.
    I managed to trace our a rough block diagram of the power stage, and I'm quite interested in the operation.
    Here are my questions.
    I noticed there seems to be no dedicated charging section in the circuit. After some googling I assume this is what they called a bidirectional power design. Would like to know if my assumption of the operation are right.
    Given that there are no diodes. I am assuming...
    05-07-2025, 09:53 AM
