Why this UPS is using 1200V IGBTs ?
  • SistMaticZ
    • Jul 2019
    • 72
    • Morocco
    #41
    Re: Why this UPS is using 1200V IGBTs ?
    Ok sam ive sent you a message on your email.
    My adress starts with ibnou......
    You can delete your email adress from this thread.
      • Jul 2011
      • 6069
      I send you a reply
      • SistMaticZ
        • Jul 2019
        • 72
        • Morocco
        #43
        I send you a reply
        Thanks for your precious replies sir.
        • SistMaticZ
          • Jul 2019
          • 72
          • Morocco
          #44
          I hope that some one from moderation staff can solve this PM lock out issue.
          • rivetcity
            Panasonic TX-P42UT30E, IGBTs on the SN board
            by rivetcity
            I'm having problems with my plasma Panasonic p42txu32e. The issue started about 12 months ago.
            I have a remote controlled main outlet so whenever I turn off the TV set at night, I also switch off the whole power outlet.
            It gives me a better feeling to know I don't have 230V on any cables, so my dog can't get hurt if he gets the idea to start chewing on something.
            About 12 months ago the TV started to have the following problem: when pressing anything on the RC to get it on, the red led would go off.
            Sometimes it would turn...
            08-12-2021, 01:25 AM
          • Biruslapio
            Samsung PL42C450 plasma X-Main IGBTs
            by Biruslapio
            Hello, the problem with this TV is it has all the Y and X voltages, but does not produce any image.
            It had a TON of cracked solder joints on these boards, fixed all that I could find, but in the last test I forgot to plug in the Y-SUS to control board flat cable, it was left dangling and possibly some pins shorted to the panel metal ground, the X-Main buzzed quietly then blew up in 3 seconds after powering up, annoying.
            Two RJH30E2 shorted, they are 360V 35A 1.7VCE IGBTs, the problem is I don't have any 360V IGBTs, only 300V or 600V, would two RJP3065 fit in? It's...
            04-08-2022, 01:16 PM
          • tiff_lee
            Replacement 'green cap' 392J 1200V
            by tiff_lee
            I had a logitech Z506 psu go bad due some glue corroding the legs of several components and the one i'm struggling to find a replacement for is a green polyester capacitor markings 392J 1200V.
            The problem is I can't find any 3.9nF caps with a voltage rating of 1200V from any reputable retailers (plenty of 100V) , this particular cap only seems to be available from Chinese sellers which leads me to believe the rating is garbage or the cap is.
            There is a thread on this particular PSU here
            https://www.badcaps.net/forum/showthread.php?t...
            05-24-2021, 05:36 AM
          • JoWed
            Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
            by JoWed
            Hello Community,
            I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
            07-01-2025, 09:32 AM
          • SoulFreeze
            Inverter Charger architecture question
            by SoulFreeze
            Hello all, I have a mastervolt charger inverter I'm trying to repair, as I have no schematics I decided to trace our some of the parts to figure out the general operation.
            I managed to trace our a rough block diagram of the power stage, and I'm quite interested in the operation.
            Here are my questions.
            I noticed there seems to be no dedicated charging section in the circuit. After some googling I assume this is what they called a bidirectional power design. Would like to know if my assumption of the operation are right.
            Given that there are no diodes. I am assuming...
            05-07-2025, 09:53 AM
