Question about bipolar electrolytics
  • Cap_search
    • 29
    • Earth
    Good morning all,
    Is it true that all the bipolar electrolytics are made/manufacturered of two "back-to-back" polar electrolytics in the - + + - configuration, and that would explain why they are usually larger than equivalent value of a common polarized electrolytic? (e.g. Muse UES)
    N.B.: polarized Silmic II are also usually larger than common electrolytic, though.
    • 31289
    Re: Question about bipolar electrolytics
    who cares, it's better to replace them with polyester or polypropylene anyway - just more expensive.
    • Cap_search
      • 29
      • Earth
      What about BP caps of 220uF or larger?
        • 31289
        never seen one.
        they probably are very expensive and hard to find too - so still possibly a way to use foil instead.
        specially as most BP caps are running below 100v
        • Hitto
          • Apr 2019
          • 95
          • Italy
          Originally posted by Cap_search
          Good morning all,
          I think not. Bipolar electrolitics are also built as single capacitors with both the anode and cathode foils oxidized.
          Back-To-Back vs. Single Cap. is more or less the same but purists swear that the second one has better characteristics. For sure there is less ESL if the capacitor is a single one and lower E.S.R. is also possible.
          • Cap_search
            • 29
            • Earth
            That's what I thought, too. Just wondered they are usually bit larger than normal polarized equivalents. Grazie.
            • R_J
              • Jun 2012
              • 9624
              Usually the non polarized caps that are larger in size handle larger currents, as an example are the ones that were used in the horzontal yoke section of monochrome tv's & monitors. I still have some Rubycon 6.8µf/50v (18mm x 40mm) I have seen people replace them with regular 6.8/50v nonpolarized and after a few minutes of running the cap heats up and removes itself from the chassis.
              • petehall347
                • Jan 2015
                • 4450
                nearly fell of my chair laughing then ... and of course higher voltage ones are bigger . strange thing i once used a polar cap for testing something that should have had non polar fitted .seem to remember it was starting a motor or something .it worked just fine on AC .
                • R_J
                  • Jun 2012
                  • 9624
                  Higher current ones "of the SAME capacity and voltage" are a lot bigger.
                  I've seen other shops/customers replace the cap with the type normally found in cheap crossover's
                  IE: 10µf/50v (6mm x 12mm) for the one I described, and they can't handle the high current. They would look at the capacity and the voltage and figure it should work. They would think there must be a fault somewhere else, They would eventually bring it to our shop and after seeing what they did I would install the correct cap and that was it, fixed.
                  • redwire
                    • Dec 2010
                    • 3912
                    I think physically bigger electrolytics have higher ripple current rating because they can get rid of the heat better.
                    One problem using two polarized electrolytics to make a bi-polar one, is the two capacitors are always mismatched i.e. 9uF and 11uF so the smaller cap can end up seeing reverse voltage, if low frequencies get passed through.
                    The midpoint is supposed in theory be zero but you get voltage there, and the cap eventually causes distortion and then shorts. So I don't make them this way anymore.
                    Lately, I always change out bi-polar electrolytic caps for film caps.
                    • mockingbird
                      • Dec 2008
                      • 5488
                      Someone on this forum mentioned once that they eventually become polarized.
                      Mr. Carlson on Youtube also has a video on how film caps really are actually polar caps.
                      I guess the only real non-polar caps are ceramic.
                      Every time I come across an NP cap in a circuit, I wonder to myself if it would be possible to re-design the circuit without the need for one. They're very common on modems.
                        • 31289
                        the film caps that are uncased that have a stack of layers with end terminals - the silver ones.
                        those wont be polarised.
                        • redwire
                          • Dec 2010
                          • 3912
                          Mr. Carlson talks about (wound) film caps being "polarized" as far as the outside wrap and a marking stripe on the case.
                          It's desirable to have the outside wrap connected to the output of a stage (not input), kind of acting like a shield. But this is only for high-impedance tube gear from days long ago.
                          • tony359
                            Bipolar capacitor for vintage Apple CRT monitor
                            by tony359
                            Good day all,
                            I have a question about some old monochrome Apple monitors.
                            Inside those monitors there is one bipolar capacitor. From the schematics I have it's part of the horizontal linearity circuit.
                            A friend replaced a bipolar 4.7uF 25V capacitor with a Nichicon bipolar 4.7uF 25V. The cap popped after about one hour. The new capacitor was much smaller than the original one but that's not a surprise as the original one was from 1980. (I am not sure whether the original was was actually 4uF and was replaced with a 4.7uF?)
                            The new capacitor:...
                            08-12-2024, 03:27 AM
                          • chth96
                            by chth96
                            06-02-2024, 07:31 PM
                          • Perry Babin
                            Derating of polymer electrolytics
                            by Perry Babin
                            There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
                            If they require derating, why would the manufacturer give them their rated voltage?
                            This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
                            https://www.mouser.com/datashe...
                            10-24-2025, 11:57 AM
                          • bulkchart32
                            i think i accidently ordered non-polarized 10uf caps for my original xbox. will this cause a problem?
                            by bulkchart32
                            i ordered a lot of caps from digikey to repair my xboxs. one thing i ordered was 50NXA10MEFC5X11-ND caps and i think they are not polarized. will this cause any kind of a problem? i really don't want to order new caps just because of this.
                            06-16-2025, 03:09 AM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
