Capacitor ID numbers
  • Madasirrah
    • Jul 2019
    • Uk
    Good evening Ladies & Gentlemen.
    I am trying to repair an early generation of a “Vax” vacuum cleaner.
    I have stripped it down to find a blown capacitor across the main on/off switch.
    Some of the markings are unreadable however it is marked with:
    40/085/56
    A quick search has told me this is a discontinued unit, however I have found an old stock/unused one on ebay, however it has a “B” on the end of the ID number. I.e 40/085/56B.
    It is manufactured by “RIFA”
    My question is, what does this “B” mean and will it make any difference?
    Many thanks in advance
    Adam
    • 31289
    Re: Capacitor ID numbers
    do NOT buy RIFA caps.
    upload a photo of the original part.
    • R_J
      • Jun 2012
      • 9624
      What is the capacitor value? It would be marked on the top. The cap is just for spike/arc protection for the switch.
      just get one from a electronic parts distributor like digikey, Rifa is the OLD manufaturer, it is now Kemet
      That number is the "Climatic Category (IEC 60068)"
      PME271 series likely around 0.1µf 275 vac
      It could be a PMR209 series (cap in series with a resistor)
      Its mainly there for RF suppression to prevent AM radio interference
        • 31289
        it's not a cap, it's a supressor.
        it has a series resistor in it.
        • MORETTIGIAN
          by MORETTIGIAN
          Title:
          Description:
          Procedure performed:
          - Removed backplate
          - Reapplied thermal compound
          - Reassembled card
          09-18-2025, 12:14 PM
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • Agent24
          Dick Smith Q-1760 linear power supply filter capacitor question
          by Agent24
          I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
          It has at least one problem.
          The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
          I have already ordered a replacement potentiometer, so that's not an issue.
          Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
          All are CapXon...
          10-21-2025, 05:39 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
