Strange fault
  • auditheman
    • Jun 2019
    • scotland
    Strange fault
    I know this may sound strange but I've been given something very strange to repair by a customer, of which is actually a vibrator!
    The problem is that upon opening there appears to be some liquid ingress damage. There are several resistor and caps that I've already replaced. There is also a processor but I think this will have some firmware so will be unable to just replace it.
    The fault is causing the unit too gyrate back and forward at a random rate.
    any ideas please?
    • 31289
    Re: Strange fault
    pictures. (of the board!!)
    and get the instructions - that may be normal.
    i cant see why you need an mcu unless something is timed or varied in some way.
    • auditheman
      • Jun 2019
      • scotland
      Re: Strange fault
      Hehe
      The other strange thing is that the camera at the tip of it appears to be recording intermittent video when the gyrating start becoming random.
      I will get some pictures of PCB.
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        Re: Strange fault
        yuck! i wouldnt repair such a thing esp. since there's "liquid ingress damage" coz that is either real girl goo or some kind of ky jelly lubricant they used. make sure u use gloves when handling and servicing that thing. dont wanna catch any stds from that! haha!
        • R_J
          • Jun 2012
          • 9624
          Re: Strange fault
          When you say THE UNIT, do you mean the USER of the device?
          • brethin
            • Dec 2008
            • 1907
            Re: Strange fault
            Nasty, but he is a Scott they love nasty.��
              • 31289
              Re: Strange fault
              Originally posted by auditheman
              Hehe
              well that sounds like a break in a wire.
              • Rictech
                Panasonic SA-MAX770PU SMPSU board fault....
                by Rictech
                Hello everyone. 😀
                As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                There are no devices that have exploded or otherwise show signs...
                08-26-2024, 01:05 AM
              • howardc64
                Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                by howardc64
                • Prior owner tried a replacement main board. No difference.
                • Samsung 2x red blinking standby LED = panel fault
                • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                07-19-2025, 10:54 PM
                ESR meter came to the rescue again today with a PLC I/O card fault
                I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                12-18-2023, 08:17 PM
              • Agent24
                What kind of fault causes this image error?
                by Agent24
                I took a look at a television for a friend, it has some serious image fault. I don't know what the cause is or if such a fault is even repairable.
                The T-con board seems to be integrated into the panel so looks even more annoying to work on than normal.
                What's the most likely cause of this problem, does anyone know?...
                09-22-2025, 11:42 PM
              • EvazX
                ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                by EvazX
                I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                However, after some time, the replacement motherboard...
                08-25-2025, 06:09 PM
