DFI nF4 recap with all polymers?
  • cmr-informatik
    • Jun 2019
    • 5
    I have some DFI nF4 boards coming in to try and relieve some nostalgic times. A few of the boards have bulging caps and I'd like to just recap the entire boards to make a fun project of several weekends.
    I am not entirely new to this replacing caps thing, having swapped out some bad caps on original Xbox motherboards while completing my EE undergrad.
    I am curious if there are any electrical issues (yes my undergrad is EE but I mostly work in CPU logic design and OS/firmware now so... it's been a while hah) with replacing all caps on DFI nF4 motherboards with equivalent polymers (cost isn't really a concern, but availability might be I suppose)?
    From what I recall, I should match capacitance and voltage spec, along with similar ESR (or lower). It looks like the circuits around the CPU are already polymers on these motherboards so I won't be replacing those if I don't have to.
    Am I missing anything? Is this really dumb ?
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3266
    • Singapore
    Re: DFI nF4 recap with all polymers?
    i have seen plenty of those with bulging caps on ebay. these dfi nf4 boards typically come with a boardful chemicon kzg caps which are known to be problematic and they are used for general filtering of the minor rails. this fits in with what we know of the failure mode of the kzg series in that the lower voltage parts typically the 6.3v caps fail the quickest.
    however, dfi was wise to use polymers in the cpu vrm and the dfi nf4 boards typically have chemicon psc blue polymer caps which are great and long lasting and dont cause issues.
    that being said, u dont need polymers in the places the electrolytic kzg caps bulged because they are low stress minor rail filtering areas where u can take liberties with the esr and ripple rating spec. there are over 20 of them per board and replacing them all with polymers will break the bank easily. just use 10k hour electrolytic caps series like panny fr, rubycon zlh or chemicon kzm. they will work fine without issue.
      • 31289
      make sure the pitch between the leads is correct when you order the polys,
      unlike electrolytics, polys can come with different pitch options for the same cap diameter.
      • cmr-informatik
        • Jun 2019
        • 5
        Thanks guys!
        I will most likely be following up with a post in the Motherboard section once all the boards and parts are here.
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
          ASUS P5GC-MX motherboard recap
          by momaka
          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
          So here is what the motherboard looked like with its original caps:
          CPU VRM area up close…...
          01-27-2021, 11:59 PM
        • Noodneek
          Replacing all the caps on the BenQ SW2700pt's power board didn't help...
          by Noodneek
          My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
          I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
          08-30-2024, 12:52 PM
        • kotel studios
          TAGAN TG380-U01 PSU - 5v shorted after replacing caps
          by kotel studios
          Hi
          Recently I got this tagan tg380-u01 PSU with bad caps on 3.3v rail (the line was 2.5v no load!). Replaced them but no go, so I've replaced all of them, apart from some smaller ones and one under the secondary heatsink. Even that didn't help so I've replaced the others. All caps are known good ones.
          Powered it on and heard the breaker pop. Opened it up and saw some smaller caps shorted together. Fixed that up but still it trips breakers. Now I get 0ohms from 5v to GND. Secondary heatsink removed and still a short, even with the PWM IC board removed. All diodes on that...
          02-14-2025, 10:10 AM
          by momaka
          03-15-2023, 10:17 PM
