Recap also the polymer caps?
  • tnynyn
    • Jun 2005
    • 9
    Quick question on the Polymer Capacitors. I have a dead board with defective/cheap capacitors, all Jackson. I am going to replace the Aluminum Electrolytic Capacitors(vented), but should I replace the Polymer ones(non vented) too?
    The Aluminum Electrolytic Capacitors are not flat at the top which is why Im replacing them. The polymer ones looks normal. Should I be worried with these (being a Jackson brand and all) or can I just leave them alone?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Recap also the polymer caps?
    what board are you talking about? can you provide a pic of the polymer caps to avoid confusion. what values are at the top of these polymer caps.
    • tnynyn
      • Jun 2005
      • 9
      The board is ABIT SA6R. Heres a pic of what Im talking about, sorry only camera I have is a camera phone. These are the smaller caps. The one just to the left (not circled in red) is the bad cap that Im going to replace (Jackson 1500uf 6.3v). Just wondering if I needed to replace the smaller caps circled in red (Jackson 100uf 10v)
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        i dont think they are polymer caps, just low value normal electrolytics. if they are only 100uf, should be fine if you leave them. If they dont have vents then they are using a different kind of electrolyte. it is rare to see them fail but sometimes they do. I did a few abit boards like that leaving them, still stable as hell.
        Make sure you replace all the jackcon 1000uf and above, they are total crap. they can bust out their bungs at the bottom of the cap and leak electrolyte all over the board. if you have leaked electrolyte you can clean it from the board and smt components using alcohol and a cotton swab. You do that when you have removed capacitors in the area and before you install the new ones.
        i hope you have success, it looks like a nice board.
        • tnynyn
          • Jun 2005
          • 9
          Thanks for the helpful info willawake!! The board has been sitting in my closet for a couple years now becuase of the caps. Now I have enough info to fix it, luckily I didnt toss out the board
            by momaka
            03-15-2023, 10:17 PM
          • Perry Babin
            How do organic polymer caps compare to liquid electrolytic for reliability
            by Perry Babin
            I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
            If not organic polymer, what would be the caps that could take the most abuse?
            08-18-2025, 04:04 PM
          • 13mh13
            Aluminum SMD caps vs thru hole caps (reliability)
            by 13mh13
            The PCB motor for 1987 Technics SLP-120 CD player has slow spin-up issues. Similar to what another tech in the below video reported.
            https://i.postimg.cc/kGrR6BpZ/image.jpg
            I replaced the three bi-polar 47uF electros but that made no difference. The orig three bi-polar 47uF electros tested okay on my ESR M-tester.
            I have not tested/replaced those alum. SMD electro PCB caps.
            Are Al smd caps are more prone to failure (or degradation) than regular thru-hole electros?
            All the thru hole electros I removed / replaced on this CDP (and most...
            04-05-2024, 07:41 PM
          • Cartel
            FORD 1996 ECU RECAP: Aluminum - Polymer worth bothering?
            by Cartel
            I will be pulling my crown vic ECU and recapping it. 3 in total, 47uf 16v x2 and a 10uf 63v
            I hope they havent puked yet. I was thinking of replacing them with Aluminum - Polymer thru hole caps. probably 47uf 25v and 10uf 80v
            They arent cheap. Anyone have any experience with them? Am I wasing my money on premium caps?
            Nichicon PLV series
            thanks
            06-01-2025, 04:58 AM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
