ECS P4VXASD2+ (v5.0) CPU fan not working and more
  • swartz
    • May 2009
    • 31
    Hi guys,
    I have an ECS P4VXASD2+ (v5.0) mobo. It has a number of problems I'm trying to fix:
    1. CPU-FAN connection is not working (tested it with working 3-pin fan)
    2. Only CPUs that require 1.75v work in it (like P4 1.7Ghz). Anything that requires ~1.5v (P4 2.4Ghz) does not boot up (no beeps and no video). I have updated to latest BIOS.
    3. There is an a oscillating whining noise coming from the CPU/VRM area (its not fan, psu, or anything mechanical I tested it all with just the cpu and mobo).
    There are 8x OST RLX 3300uF 6.3v caps around the CPU socket. None of them exhibit any visual signs of failure. In fact there are no visibly failed caps anywhere on this board.
    Can all/any of these symptoms be the result of bad caps? Why would a fan connection not work??? Same fan if plugged into the sys_fan header works as expected.
    PS. This exact same mobo has many cloned versions as per this page http://www.hardwaresecrets.com/article/65.
    - PCChips M922LU v5.0
    - Matsonic MS9147C
    - Amptron XP4-922LU
  • lucky13
    • Aug 2007
    • 412
    Re: ECS P4VXASD2+ (v5.0) CPU fan not working and more
    So have you make any headway on this?
    I suggest you replace those OST caps first. That might resolve your points 2 & 3.
    As for the cpu fan header issue, perhaps one of the transistor for it is burnt. Look carefully at the small 3-legged part near the header.
    Do you have a digital multimeter?
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Sometimes there is a fuse for the fan header, make sure there isn't one burnt out.
      They're a small square, usually green. Unlikely a ECS board has them but it might.
      • MMH3
        Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
        by MMH3
        i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
        Never ever i experienced problems with that.
        Now i have one 5050sff machine, where this jumper isnt working at all.
        I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
        The history of the machine is that i used it in my office...
        03-23-2025, 09:28 PM
      • DynaxSC
        GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
        by DynaxSC
        I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
        There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
        The board is generally working now, all PCIe ports are working, Windows installs normally.
        However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
        The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
        03-10-2025, 12:27 PM
      • obelix24
        Macbook Air 2020 (a2179) - touch id not working
        by obelix24
        Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
        I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
        02-09-2025, 12:57 PM
      • hopkok
        Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
        by hopkok
        Hi masters, I need your help.
        I am working on Lenovo Legion 16ITHg6
        Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
        INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
        My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
        AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
        Power LED is not working as well, power button working well.
        UI26 ??? is there any firmware too? Powered by +3VALW_AG.
        Motherboard...
        05-04-2025, 09:35 AM
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
