Will these work are good replacements for backordered items?
  • OberAgain
    • Nov 2014
    • 25
    This is the backorder:
    https://www.digikey.com/product-deta...mSeq=279516639
    Here are the possible replacements - I was not sure about the ripple current and impedance being different so making sure they will work... this is for a
    Samsung 245BW Monitor
    I assume this would be the good replacement - was listed as a Substitute by Digi-Key but was not sure if that meant in every way (obviously some differences but dont know enough to know if they are differences I can work with)
    https://www.digikey.com/product-deta...mSeq=279518969
    Then I searched out this product - what looked like the Panasonic version of the product
    https://www.digikey.com/product-deta...mSeq=279519113
    Would either of them work as a good substitute? any one work best? or another item that might be even better?
    Thank you so much! You have all helped me save so much over the years, fixing my triple monitor setup over and over - you are all awesome!
    Thanks,
    -Patrick
    • 31289
    Re: Will these work are good replacements for backordered items?
    the panasonic FR is by far the best.
    the rubycon YXF is not even in the same class.
    • OberAgain
      • Nov 2014
      • 25
      Thank you much, greatly appreciated! Up to 4 Samsung 245bw repairs so far thanks to this forum, specifically Selldoor's excellent help on my first attempt. Loving this monitor and cant find any I would rather replace it with so I am very grateful to be able to repair it!
      -Patrick
      • hollox123
        ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
        by hollox123
        Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
        1. Laptop keyboard doesn't work
        2. The backlight on the laptop keyboard doesn't work
        3. The x2 side LEDs (red) on the laptop don't work
        The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
        I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
        But I am strongly aiming that it is somehow a BIOS-related problem,...
        05-11-2025, 08:05 AM
      • melvinvdb
        Lenovo y520-15ikbm most of the time doesn't turn on
        by melvinvdb
        I've repaired a few laptops in my life but this time my own laptop died😂.
        Funny enough this one is a bit tough on me.
        It doesn't turn on (most of the time).
        Model: Lenovo y520-15ikbm (NM-391).
        The only way to make it turn on is:
        1) unplug battery + charger + rtc (seems irrelevant)
        2) wait a minute
        3) plug battery/charger in
        4) on charger plugin, laptop turns on by itself. On battery plugin you have to press power button. Sometimes nothing happens and you have to try again.
        5) when it turns on it also displays POST...
        08-15-2024, 12:28 PM
      • DrDos
        kenwood kr-6030 Mosfets?????
        by DrDos
        Hello everyone, I have decided to try and replace the mosfets in my power amp (the one with relay and left and right sides) on my kenwood kr-6030. I'm trying to get the A side of my speakers working. I have replaced all the caps in the power board and I thought why not change the mosfets. They seem to be working since I have great music coming out of the B side speakers and since I am not an electronic guru (but I am learning) I don't want to make any mistakes. The mosfets I have are listed A913 so I guess 2sa913 and 2sc1913. Can't really find those in mouser or digikey at least with the info...
        09-20-2025, 04:42 PM
      • irepair559
        Ps4 1215a hdmi diode readings good everything good but no pic??
        by irepair559
        PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
        01-05-2023, 12:32 AM
      • ResoluteHawk
        Lenovo Legion S7 15ACH6 Not Posting
        by ResoluteHawk
        I have a customer that brought in a Lenovo Legion S7 15ACH6. The problem is that the laptop is not posting.
        My first thought was to take out the DRAM and put it back in.
        No POST.
        Then I swapped the dedicated RAM with good known working RAM.
        No change.
        I then measured to see if 1.2V was being generated for the memory to turn on, so I measured PL600 which is where the output of the 1.2V rail is.
        Resistance was good; measuring ~40Ohms with the slotted RAM in.
        I took the slotted memory out and measured again.
        Resistance with...
        12-02-2024, 10:17 AM
