Need help! Identify an AC capacitor
  • sitran12
    • May 2009
    • 13
    Re: Need help! Identify an AC capacitor
    2 months later I wanted to share the final results - after speaking with our local Brother's lab technician I followed the technician's advice and removed the cap entirely. He says the cap is an old noise suppression part that is no longer needed.
    This solved the problem and the machine works perfectly.
    I know that from a safety point of view it might have been better to put on a Y capacitor, but I prefer to replace the entire foot pedal for 20$-30$ if any problem re-occurs.
    thanks everyone for the help
    • Toasty
      • Jul 2007
      • 4171
      >>He says the cap is an old noise suppression part that is no longer needed.<<
      I disagree.
      i.e.- Magically the unit no longer generates line noise...?
      This looks to be a carbon-disc type of speed control. As pressure is applied, the little discs are squeezed together more tightly and the resistance goes down. Interference can be generated from:
      1) the on-off switch portion
      2) the discs because they move a bit and can arc
      3) the controlled units motor (it should have its' own suppressor cap, but...)
      Also, the cap reduces burning/arc of the on-off switch contacts. Because the load is inductive (motor), when those contacts open, there is an EMF feedback pulse. That cap will help to quench the arc that can/will be generated.
      >>He says the cap is an old noise suppression part...<<
      I said that back in Post 2...
      https://www.badcaps.net/forum/showpo...77&postcount=2
      Toast
      veritas odium parit
      • sitran12
        • May 2009
        • 13
        Yeah, I liked the way you put it..
        It is a carbon-disc speed-control. But I don't really care for line noise (unless it can be hazardous) because now we only use the machine once every 2 months or so..
        I just got a gift from my aunt - another Brother machine . It's almost identical in model and age but the condition is much better, so I'm moving to the new machine and if anything funny happens - then its a whole new ride with you guys
        • MORETTIGIAN
          Capacitor detached from PCB – RTX 2070 Super Founders Edition
          by MORETTIGIAN
          Title:
          Description:
          During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
          I did not notice it detaching, so I am unsure of its original location on the PCB.
          Procedure performed:
          - Removed backplate
          - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
          - Reapplied thermal compound
          - Reassembled card
          Observed behavior after reassembly:
          - GPU powers on and operates normally under...
          09-18-2025, 12:14 PM
        • BlackBurn
          Help to identify a laptop mainboard SMD capacitor LA-9982P
          by BlackBurn
          I have an Dell Inspiron 15 3537 laptop mainboard (LA-9982P Rev. 3.0 (A02)) with a blown SMD capacitor as shown in the attached images. However, there is no printed specifications near the capacitor or a codename for the capacitor to identify the specification of the capacitor to replace it. I wonder how to identify the capacitor since the mainboard schematics are also useless as the capacitors are not named on the board. Any help would be highly appreciated.
          Thank You. Stay Safe.
          Chamara...
          11-27-2020, 08:30 AM
        • chth96
          If I replace with inferior capacitor, Is it No harm to other IC components at all?
          by chth96
          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
          I know that these capacitor will not last as long as nichicon capacitor...
          12-22-2023, 04:34 AM
        • chth96
          How can I test non-polarized capacitor?
          by chth96
          I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
          I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
          And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
          I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
