Help with cap ID: Panasonic FJS?
  • Ginguskhan
    • Mar 2009
    • 36
    I have these VRM caps on an ASUS A8N SLI Motherboard
    Reads "FJS +105C" and has an "M" logo with a thin circle around it. They are listed at 16v, 1000uf, have a golden polarity marker and black base color. I am guessing these are some type of Panasonic FJ Series?
    1) What is the full ID of this cap?
    2) Is FJS same level as FJ? Or better/worse?
    3) What are good replacement caps? (I have no bad ones, just curious)
    Thanks,
    Ginguskhan
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Help with cap ID: Panasonic FJS?
    The only reference to FJS I can find was that they were used on some Dell XPS motherboards.
    "M" logo with a thin circle around it... -> Matsushita - Panasonic, same-same.
    Not real unusual for Matsushita/Panasonic caps to exist with no data sheets available.
    FL and FJ don't have any publicized data sheets. Possibly a few others.
    Presumably they don't make data sheets available when their intended market is 'industrial partners' or whatever. [Not retail.]
    Those in the photo are in Vcore.
    FL, FJ, MBZ, MCZ, WG and a few others are all fine there.
    If you are looking for something to worry about you haven't found it yet.
    Short of heat issues you aren't likely to blow one of those.
    Mann-Made Global Warming.
    - Dr Seuss
    • Ginguskhan
      • Mar 2009
      • 36
      PC Bones, thanks again. You know yer caps. I checked far and wide to no avail for the FJS series Panasonic caps. Though, since panasonic FJ are listed on the "good capacitors thread" I figured these were good to go.
      Last Q: the 4x 16v 1000uf KZG caps....are they the +12v circuit that is measured on the posted motherboard voltages? Or, what is the circuit these caps are in called?
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Caps ~could~ be on any voltage less than their rating.
        The larger 16v caps are usually on +12v in the VRM which is the regualtor for CPU power.
        VRM-input side is on +12v power from the PSU.
        [That's what the brown ones in your photo are. I assume those are the KZG you see.]
        VRM-output side is the Vcore [CPU] voltage.
        [That would be the FJS in the photo.]
        [[ VRM-input side on older motherboards [P3-ish] is usually on +5v power but using +12v power was allowed. ]]
        16v caps do get used in other places.
        A motherboard manufacturer may choose to power something from +12v through a POL [Point of Load] regualtor on the board and that might have a 16v cap on the input side to the regulator.
        Small 4,5,6 mm caps on motherboards are often 'upped' in voltage either to use caps with better Ripple ratings or because the circuit is connected to external wiring [USB, PS/2, sound] that might get suddenly disconnected under load causing a voltage spike.
        Fans are also powered by +12v and one or two small 16v+ caps near a fan connector is common.
        ... KZG, not so good to see.
        Sometimes fail due to heat issues and don't always don't bloat when they go.
        [Their cousin KZJ uses the same electrolyte and I suspect they have the same issues but KZJ aren't very common so there isn't enough 'history' with them to call it.]
        Other series' of Chemicon caps should be fine. KZG is the only one with lots of complaints.
        I think your board is too new for this to matter but since I'm on 'good brands with problems' ...
        At least some [maybe all] Nichicon HN and HM manufactured from 2001 thru 2004 were defective. They goofed and put the wrong amount of electrolyte in them. There was a short run [few weeks or months maybe] within that time span that they were ALSO contaminated with some disinfectant or cleaner they use at the factory. Nichicon was honest and issued press releases for both problems but not everyone has seen both announcements and as the problems overlapped and applied to the same series' there is some conflicting info on the web.
        Both problems only affected HN and HM series made from 2001 thru 2004.
        Other series' of Nichicon and HN/HM made before or after those dates should be fine.
        - Dr Seuss
        • Ginguskhan
          • Mar 2009
          • 36
          Wow, I am enlightened about circuits in MOBOs. Very useful post for any badcaps.net follower. PCBones u da man!
          If I knew you, I'd put one on my tab and toast to it!
          • zuhr14
            • Dec 2013
            • 23
            • Antarktis
            Old topic,
            but coincidentally, I was looking for a old Matsushita series FJS too. Panasonic support said, that the replacement series is FR. Maybe it will be useful for someone.
            • mockingbird
              • Dec 2008
              • 5484
              FR is not a suitable replacement to FJS... FJS is almost equivalent to FJ, FL, or FJZ... It falls into the ultra-low ESR category and should be replaced with Nichicon HM/HN, Rubycon MBZ/MCZ, Sanyo WG, etc...
              • zuhr14
                • Dec 2013
                • 23
                • Antarktis
                OK,thank for info,i am waiting to next answer from Panasonic support.
                I asked for detailed informations about mysterious, undocumented FJS series.
                • mockingbird
                  • Dec 2008
                  • 5484
                  Good luck, the only way you're going to get those datasheets is if you know someone on the inside... Just search for the FJ datasheet if you really want to, it's posted as an attachment somewhere on this forum... Theres no real need to get the datasheets for all the other series. AFAIK and IIRC, they're all practically the same, and I don't think Panasonic ever produced anything like Nichicon HZ or HN class.
                  • tmiha71
                    • Apr 2010
                    • 130
                    Think, they're 3000 hours parts -> should be better than 2000 hours parts...
                    • Andre Gilbert
                      by Andre Gilbert
                      Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                      Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                      11-20-2024, 08:52 PM
                    • David Stroe
                      AOC CQ27G2U/BK - in need of data sheets
                      by David Stroe
                      I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
                      I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
                      Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
                      Main Board: 715G9500-M0C-B00-005K
                      T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
                      If someone could please provide any of these data sheets, it would be awesome....
                      05-31-2025, 11:12 AM
                    • AquaMan Ua
                      by AquaMan Ua
                      05-17-2025, 09:40 AM
                    • Raulnn
                      clean hisense inner sheets
                      by Raulnn
                      Can you clean the internal sheets of a tv? I have a 58-inch TV and I don't know if it's worth cleaning the sheets. I have seen that it has dirt on the sheets and the leds are blown. I don't know if they look good when you clean the sheets. Thanks in advance.
                      01-22-2023, 05:19 PM
                    • stecos
                      Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
                      by stecos
                      Hi everyone!
                      For my passion for technology I'm now collecting several...
                      11-28-2022, 11:39 AM
