Looking for information about Panasonic FAU (or F AU) capacitor
  • Y. Signal
    • Apr 2018
    • 77
    • Spain
    Hello, I've found a dark blue / silver Panasonic 1800uF/6.3V capacitor labeled as "Panasonic 105ºC FAU", do you have information about this series? suitable replacement suggestions are welcomed. It belongs to a Sega Saturn power supply that I want to recap.
    • 31214
    Re: Looking for information about Panasonic FAU (or F AU) capacitor
    probably very old, F = low impedence.
    A i never heard of, C is next up, then M or F
    (or K if it needs to be smaller)
    so FC or FM or FR should be fine.
    dont trust them from the external apearence btw, i have seen FC leak around the wires when they get old.
    • Y. Signal
      • Apr 2018
      • 77
      • Spain
      Thanks, will use one of those.
        https://industrial.panasonic.com/ww/...a-discontinued
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          budm nailed it above. These are Panasonic FA series. If I remember, these were discontinued in favor of the FC series... so they are supposedly equivalent.
          I wouldn't recap these, as they are probably still okay, unless they were heat-abused.
          I've seen Panasonic caps leak only when abused with too much heat while soldering/desoldering and from physically applying too much pressure on the caps sideways (i.e. pushing on them sideways while being soldered). Otherwise, no, I've never seen them leak. They are very reliable.
          If you still chose to replace them, I suggest saving these older Panasonic caps if they still read in spec - they can still be used for a temporary recap in place of many cheap China garbage caps today found in just about every electronic device. Sad when you see 20+ year old caps do better and last longer than yesterday-made cheap garbage.
          • Y. Signal
            • Apr 2018
            • 77
            • Spain
            Thank you, I take good note. I thought it was a good idea to replace all the capacitors >25 years old even if they are very good, but I'll leave my other PSUs if the electrolytics used are not problematic.
            For this PSU I'm gonna recap since I've already bought them. Fortunately the replacement I ordered for this FA U is Panasonic FC.
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • anty
              Lenovo Yoga 13 mb: Yoga 13 MB Panasonic capacitor identification
              by anty
              Panasonic capacitor identification...
              07-07-2023, 01:06 AM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              How can I test non-polarized capacitor?
              by chth96
              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
              06-02-2024, 07:31 PM
