Help with DE-5000 results
  • elgato
    • Apr 2013
    • 32
    I am trying to use the DE-5000 to test some caps. I am new to this and would appreciate some input.
    Junzl 100uF 400V
    In Cs Mode:
    100hz Cap 88.17 ESR .9
    120hz Cap 87.95 ESR .8
    1khz Cap 85.6 ESR .57
    10khz Cap 77.1 ESR .52
    100khz Nothing "OL"
    Rs
    100hz .90
    120hz .83
    1khz .57
    10khz .51
    100khz.49
    What results should I be looking at and why?
    The datasheet seems to spec 100khz?
    ESR meters like the Atlas ESR70 or the Blue appear to simply auto adjust frequency and simply display values. What are they doing?
    Thank you.
    • 31028
    Re: Help with DE-5000 results
    ESR70, blue and a few other are fixed frequency afaik.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      The cheap meters don't do a proper test, but it's a close enough approximation to give a decent result over a wide range.
      A high end meter like yours has the ability as you found to test at the frequency listed in the datasheet.
      It's simply a more reliable method vs "winging it"
      • elgato
        • Apr 2013
        • 32
        Given this data sheet. What is the appropriate test frequency for 1. Capacitance, 2. ESR
        https://cdn.badcaps-static.com/pdfs/...0df5a37c01.pdf
        Rule of thumb appears to be 120Hz for over 10uF and 1kHz for under 10uF. ?
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          The rule of thumb is that General Purpose caps are 120Hz.
          And low impedance (ESR) caps are rated for 100Khz.
          But it should always be listed in the datasheet.
          • quickname
            Cyberpower 1500AVR UPS repair
            by quickname
            I'd like to start out by thanking this forum for providing the info to be able to repair my 15 year old CP1500AVRLCD UPS. Here is all the info I gathered during my trouble-shooting and re-capping.
            Like clockwork, I've had to replace the SLA batteries every 4 years. It was about that time and the UPS was acting like it needed new batteries... randomly shutting off with AC present, not being able to charge fully, and poor runtime when AC was removed. So, I replaced the batteries but noticed that it was not charging properly.
            I decided to verify that the batteries were...
            11-12-2023, 09:57 AM
          • DynaxSC
            Each GPU reballing produces different MATS results, looking for root cause ?
            by DynaxSC
            I have an Nvidia card which makes me wondering, what is the root cause for Mats errors. The story is as follows:
            1. When I received the card Mats showed one memory with errors.
            2. Replaced the memory chip, but no change, still same error, so memory chip is ruled out.
            3. Made a carefull reballing of the GPU, MATS showed 3 memories with errors, the one before, and 2 other new chips.
            4. Made a second reballing of the GPU and Mats shows again only one memory chip with errors, the same on as in the beginning.
            5. Made...
            12-11-2024, 07:44 PM
          • LEECH666
            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
            by LEECH666
            Good day ladies and gentleman!
            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
            01-19-2024, 05:46 PM
          • TheDragon
            Frequency measurement
            by TheDragon
            I have a old JBL car amplifier that has electronic HP/LP crossover with pots.
            Now, the pots don't have any increment markings, just 32-320Hz variable.
            I would like to set these at around 100Hz in HP, as close as possible, so the front component speakers don't play that frequency.
            I don't have a Oscilloscope but apparently my Uni-T multimeter can read frequencies. So, I sent 100Hz test tones via phone app, measured the output on the amp and it reads 100Hz. I sent 1Khz and 10Khz and it measured correctly, all in Flat position. Great I thought.
            I then switched...
            05-13-2019, 08:27 AM
            Has anyone had good results from lithium rechargeable battery with 1.5 volts
            by sam_sam_sam
            I am looking for lithium ion rechargeable battery that have 1.5 volt output that have had good results
            I see that there are quite a few China made batteries out there ( with different names ) that have this requirement but the claims are not always correct
            I have used this brand before Kentli and the results are so-so but the batteries are not cheap
            You might get 500 cycles out of them before the run time drops off considerably which they claim 1500 to 2000 cycles
            Or the batteries become ( heater cells when are being charged )
            02-03-2020, 03:49 PM
