Capacitor sleeve shrinkage?
  • John843883
    • Nov 2012
    • 71
    As the title suggests I've come across a capacitor where the sleeve appears to have shrunk and retreated up the side of the capacitor body.
    Anyone know what the causes of this sort of thing would be? The capacitor is a Rubycon BXA 400V 2.2uF, capacitance measures fine but ESR is a bit high at 16 ohms. No signs of bulging or leaking.
    I'm not trying to repair anything but I'm just curious as to what causes the sleeve to pull back like this? It came out of an old 8w cfl bulb and this capacitor caught my eye, so maybe its just heat related? I couldn't find the missing bit inside the lamp base so it hasn't flaked off.
  • R_J
    • 9624
    Re: Capacitor sleeve shrinkage?
    It could be from a component that is mounted close to it that gets hot, like a resistor, or it could have been cut a bit short when it was made, I would not worry about it
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      I would replace it. The cap heated up for some reason.
        • 31291
        heat, the sleeve is screenprinted heatshrink tubing
        • R_J
          • 9624
          I'v seen that before, if the cap. got really hot the heat shrink would be pulled down from the top also, and it's not
            • 31291
            depends where the heat came from.
            • CapLeaker
              Leaking Member
              • 8352
              For me, it depends out of what piece of electronics it came form. It looks like to me it is the main cap from a CFL or similar. So in that case I wouldn't bother. If that cap would be in something important you need to count on, it would be replaced in a heart beat.
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
