Does my motherboard model have a known problem with bulging caps?
  • berrypievision
    • Mar 2009
    id:
    core
    description: Motherboard
    product: MS-6540
    vendor: MICRO-STAR INTERNATIONAL CO., LTD
    physical id:
    0
    slot: �PRIMARY IDE
    id:
    firmware
    description: BIOS
    vendor: Phoenix Technologies, LTD
    physical id:
    0
    version: 6.00 PG (03/10/2004)
    capacity: 448KiB
    capabilities: isa pci pnp apm upgrade shadowing escd cdboot bootselect socketedrom edd int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer int10video acpi usb agp ls120boot zipboot
    id:
    cpu
    description: CPU
    product: Intel(R) Pentium(R) 4 CPU 3.00GHz
    vendor: Intel Corp.
    physical id:
    4
    bus info:
    cpu@0
    version: 15.3.4
    serial: 0000-0F34-0000-0000-0000-0000
    slot: Socket 478
    capacity: 4GHz
    width: 32 bits
    clock: 200MHz
    capabilities: boot fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe constant_tsc pebs bts pni monitor ds_cpl cid xtpr
    configuration:
    id = 0
    Hope the information helps.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Does my motherboard model have a known problem with bulging caps?
    I have never seen one with bad caps before, but then again i've never seen this specific motherboard.
    A look on google images shows that it has at least some teapo caps (bad on motherboards,) but thats what I can see from some fuzzy small picture.
    Post some pics of it if you are worried.
    • Toasty
      • Jul 2007
      • 4171
      Are you experiencing problems? Weird shutdowns, Windows won't restart, random restarts, programs lockup for no apparent reason, system hangs, BSOD's, etc.
      Easiest way is to take a look like 370 said and post up some pics.
      Cheers!
      Toast
      veritas odium parit
