Polymer capacitor confusion.
  • John843883
    • Nov 2012
    • 71
    Hello to all who read this,
    Friends PC stopped working and I found this motherboard capacitor at an angle with one of its legs pushed out. Is this a known failure mode for these capacitors? He swears it hasn't been knocked. Wiggling it does confirm that the capacitor body is separate from the exposed leg.
    The PC model is ASUS M11AD and motherboard is h81m-a_dp/m11ad/dp_mb.
    The capacitor in question has "5KU22 270 16v" printed on it and is through hole 8mm wide by about 10-12mm high (hard to tell exactly without removing it). Not sure about lead pitch as I haven't removed the board yet but 3.5mm seems to be common online (will check before purchasing).
    I'm having trouble identifying this particular capacitor model to find its datasheet, is it actually a polymer or some other kind? Can I use a regular low ESR electrolytic or does it need to be this same style?
    I've sorted a short list on RS components but there seems to be a varying mixture when it comes to lifespan hours, some rated for 2000 hours whilst others are 5000 (they all appear to be low impedance at 100khz).
    So my questions are:
    1. Is this a polymer capacitor or some kind of electrolytic? I've read online that there can be hybrids which look exactly the same as regular polymers.
    2. If so can I substitute it for a regular low ESR electrolytic?
    3. What lifetime hours should the new capacitor have? Like I said many of the polymers I've found have a varying life-hours rating, some much lower than electrolytics.
    4. What ripple current ratings should I choose for this application? Looks to be an input filter for the RAM DC-DC converter, its connected to the 12v rail through a diode and ferrite bead and feeds the DC-DC converter next to the RAM slots.
    5. The replacement candidates have ESR ratings of 10-12mohm, is this low enough?
    6. Do these types of capacitors fail like this often? I've metered a few surrounding silicon devices and nothing appears to be bad.
    Any advice for this polymer virgin would be greatly appreciated!
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    Re: Polymer capacitor confusion.
    1. its an apaq polymer. asus luvs using that brand for its mid and low-end boards.
    2. NO. the ram *might* become unstable. i've had junk caps make ram unstable on some of my boards.
    3. it depends on how long your friend wants to use the board for before upgrading his computer and how long he uses the computer each day. if he only needs the computer to last for a few more years before upgrading to a better computer and/or he only uses the computer for 12 hours a day, then get 2000 hour caps. cheaper too.
    if he intends to use the computer till it breaks or he leaves the computer running 24/7, then get the 5000 hour caps.
    4. and 5. suitable replacement series are chemicon psc or psf series, nichicon fpcap L8 or NU series, panasonic oscon sepc series.
    6. the cap is right next to the dimm slots, so its not uncommon to accidentally bump or knock into them with your fingers when installing the ram sticks. (fat-fingered user error?)
    its also possible overheating caused the leg to come off from inside the cap. i've had some caps come off with the legs still stuck to the board when i overheated the cap while desoldering the cap.
    its also possible a mosfet shorted and overheated and passed the heat to the nearby cap and overheated the cap also.
    lastly, asus marks the polarity in opposite fashion compared to others. so the shaded side of the cap silkscreen circle is the POSITIVE terminal of the cap! take note of the polarity of the old cap and be careful of the polarity when u solder the new cap on!
    • John843883
      • Nov 2012
      • 71
      Using greentext to quote as that's what the cool kids do and I can't work out how to quote only certain areas of text.
      Thanks! Found the datasheet now, its a 160AR5K271M08A2C http://www.apaq.com.tw/images/Product/4317440559_SE.pdf
      Duly noted!
      Well he's a bit of a gamer but always turns it off after use.
      Thanks, I've compiled a shortlist on RS components and will include it with the post. As you can see there is a bit of a stock shortage right now with some of the more desirable caps, looks like I'll have to make a compromise or wait a while.
      Well he swears that nothing was touched, the PC was store purchased and still stock.
      Out of the caps that are in stock which would be the best bet? The original cap had an esr of 10mohm and ripple current rating of 5.2 amps.
      I've put numbers above them to make it easier to pick out. 5 does have a slightly higher temperature rating than the others so maybe that'll offset the 2000 hours a bit, number 2 is 5000 hours but the ripple current rating is 700mA lower than the originals.
      • mariushm
        • May 2011
        • 3799
        Any of those will work, I'd go with Nichicon or Panasonic.
        Ignore the temperature bit, the VRM for the memory won't be hot so the capacitor won't heat up ...
        For polymer capacitors, the lifetime is calculated with formula L = Lo x 10 ^ [(Tm-Ta)/20]
        So a 2000h@105c cap being warm at 65v all the time will last for 2000 x 10^[(105-65)/20] = 2000 x 10^2 = 2000x100 = 200 000 hours of operation until the capacitor will still work, but will be degraded by some amount (like 20% less capacitance, 10-15% higher esr, stuff like that)
        • John843883
          • Nov 2012
          • 71
          Update: Its alive! Funny thing is the blown cap wasn't actually the cause of the PC problems, it was seemingly running with it half hanging off the motherboard! I guess the smaller ceramic capacitor in parallel to it was just enough to keep the 12v>RAM voltage (1.5v?) switcher stable.
          I actually went with the Wurth Elektronik 870135374004 in the end as the ripple and maximum temperature specs were a bit better https://uk.rs-online.com/web/p/products/8392297/
          Haven't tried this brand before so only time will tell.
          • coreAngel
            • Oct 2014
            • 124
            I have been meaning to try the Wurth brand solid caps, but being solid caps they are much more reliable than cheap unheard of brand electrolytics.
            Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
            • MORETTIGIAN
              Capacitor detached from PCB – RTX 2070 Super Founders Edition
              by MORETTIGIAN
              Title:
              Description:
              During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
              I did not notice it detaching, so I am unsure of its original location on the PCB.
              Procedure performed:
              - Removed backplate
              - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
              - Reapplied thermal compound
              - Reassembled card
              Observed behavior after reassembly:
              - GPU powers on and operates normally under...
              09-18-2025, 12:14 PM
            • chth96
              Should I replace polymer capacitor?
              by chth96
              a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
              I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
              Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
              Is this ESR value of polymer capacitor correct?...
              11-18-2022, 04:22 AM
            • eccerr0r
              solid polymer electrolytic capacitor go boom?
              by eccerr0r
              Anyone had a solid polymer capacitor fail for whatever reason?
              How do they fail? Do they explode, go open, short out, ?
              How about for different reasons: forcing excessive ripple current, overheating, voltage too high, reverse voltage?
              Just wondering about the causes for a potential shorted solid polymer capacitor... trying to debug a board that has a ~4Ω "short" on a track... it may or may not be a capacitor but was wondering what if it were...
              07-25-2022, 07:12 AM
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
