Charts Of Old Cap Values And Their Replacements.....
  • He's Dead Jim
    • Jul 2007
    • 16
    I made this chart to begin to keep track of comparisons between old and new cap for every motherboard that I will be recapping.
    This particular chart was made from recapping a "Whitney" motherboard from an IBM Netvista.
    Feel free to add your own charts so those who are new at this can have some values to compare and some discussions about those values.
    Also, if you feel that i have left out some values or that this can be improved upon, please speak up..
  • lucky13
    • Aug 2007
    • 412
    Re: Charts Of Old Cap Values And Their Replacements.....
    Why are some of the esr values gone up significantly?
    I am thinking you might want to record the brand & series of the original and replacement caps too?
    • He's Dead Jim
      • Jul 2007
      • 16
      yep yep...
      good idea...
      thanks...
      • rashidjafar
        Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
        by rashidjafar
        I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
        Values for :-
        PC43 : Capacitor [3x1.5mm]
        PL7 : Inductor [2x1mm]
        PC39 : Capacitor [1x0.5mm]
        Any ideas would be appreciated.
        I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
        08-07-2025, 05:10 PM
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
      • Kobok
        Different (lower) resistor values on PCB?
        by Kobok
        Dear Alls,
        For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
        09-19-2022, 07:30 AM
      • skdsp
        Need help identifying resistor values near BIOS chip on ASUS Zephyrus G14 GA402XV
        by skdsp
        I purchased a laptop that the previous user had tried to remove and replace a BIOS chip using a soldering iron not knowing that there is a ground pad under the 25R256JWEQ chip. In that process he damaged the BIOS chip and 3 of the resistors near the IO3, CLK, and IO0 pins. I have programmed a spare 25R256JWEQ chip using a CH341A programmer but not sure what values those resistors should be. If anyone has a boardview of this area and can provide those values that would be very useful for me.
        Attached is the photo.
        Thank you!
        09-27-2025, 09:05 PM
      • kalauzz
        VW224T ASUS Capacitor values replacements
        by kalauzz
        Greetings all,
        I got this LCD that was on the way to the dump from my company IT.
        The problem was a blinking led and the screen that was trying to light up lcd lamps , cycling endlessly.
        I struggled a bit disassembling it, because is better assembled than other brands in my opinion.
        I found on the secondary of the power board (driving the lamp inverter I think) a 1000uF 25V swollen and I tested the other 5 or 6 of same or other values desoldering them (all more or less ok).
        I had only a 1000uF 16V so I used 2 salvaged 470uF 35V in parallel.
        Everything...
        11-12-2020, 04:27 AM
