New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Good catch - I thought they were low-voltage Sanyo (from the K-vent) and never suspected them. These Fujitsu 4v Polymers are very widely used by Intel and others for Vcore filtering on P4 boards - I've seen a lot of D845GLLY, D845WN, D845PESV, etc., at the local assembler/repair shop that use this capacitor and have startup and random reboot issues.
I think I'll advise replacement with the widely available Rubycon YXG 1000/6.3v and see what happens.
Any idea if the failure occurs because of incorrect polarity? I can't imagine that Intel would make that error on production boards, but stranger things have happened.
no i would not expect that. like said earlier in the thread moisture in the caps is the issue. it is a manufacturing problem.
having seen where they are usually in the board i would substitute rubycon ZL at the least. oscon or rubycon MBZ would be nice. ZL is easily available.
Wouldn't it be better to just replace these Fujitsu RE's with the same uf rating and as close voltage as possible?
The reason I ask is I have an MSI 6340 ver 1 which had its 2700uf 6.3v caps replaced with Nichicon PJ. It also has four of these Fujitsu RE caps (2 - 4v560uf & 2 - 4v820uf)
The history of the board is not known. I received the board which showed obvious signs that someone did not have the soldering skills to properly solder the 2700uf 6.3v caps...cold solder joints. The board would not even POST.
I corrected the cold solder joints, and then flashed the latest version of the bios using the hotflash method (flashed the bios chip in another board). Then the board POST'd once for about 5 seconds. Then it shut itself down, and I haven't been able to get it to POST again.
Upon reading this thread, I replaced the 4 RE's with Nichicon HE 1000uf 10v, but still it does not work. (That's all I had)
Any suggestions? Can't seem to find 560uf 6.3v in either Nichicon HE or PW series.
if you look at the intel board in the first post of this thread it has rubycon MCZ 820uf 6.3v for vcore next to the fujitsu. i have seen this to be common on good boards. i would recommend that you go higher than 560uf 6.3v for al-caps but similar for polymer.
those should be fine. you can replace the other 2 RE caps with similar to see what happens.
matching or exceeding the design specification (i am talking about actual performance not just uf and v values) is only going to affect overclocking stability etc. as long as you dont put insanely large values on the board you should get a post.
it is possible the previous owner's soldering damaged something. needs more troubleshooting.
If I understand your reply correctly, if I can find capacitors with the same uf values (560uf & 820uf) but at a higher voltage (6.3v) it would be OK since I am not into overclocking? Looks like I will be able to source the 820uf from www.mouser.com (Nichicon HE 820uf 6.3v) and the 560uf from www.digikey.com (Panasonc FC 560uf 6.3v)
Thanks in advance
if you replace polymers with aluminuns double the capacitance.
the post problem is not likely related to these caps.
p.o must have damaged it or the old caps did.
[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1. System Information:
Model: Lenovo ThinkPad T14 Gen 1
Machine Type: 20S1S4E600 (Intel i7 variant)
Current BIOS: N2XET42W (1.33) - Latest version
BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
What I'm trying to achieve:
Replace the default "LENOVO" boot logo with a custom image during POST. 🔧 What I've tried:
at firs, i hope this is the right place to post my question.
Im looking for a tool to change the bios logo.
everyone knows when you turn on your laptop/pc you will see the manufacturer logo like lenovo, hp, dell...
i know that HP has a build in option to change the splash logo.
but i want to change the manufacturer logo to an own logo.
I try'd Change Logo 5.0, but when i make a backup of an laptop and edit the logo and flash the editted version back on the laptop the logo diddnt change.
Fujitsu D757 sff desktop pc with company logo and it doesn't work to restore the factory logo with UefiModL tool. I need to restore many of these machines to the factory Fujitsu boot logo! Does anyone know a solution?
