New Caps for amp power supply
  • Sparkey55
    • Jan 2010
    • 1523
    Re: New Caps for amp power supply
    https://www.ebay.com/itm/1x-10000uF-...53.m1438.l2649
    This is the best match for that amp.
      • 31086
      dont use ebay for caps.
      • redwire
        • 3910
        They are 10,000uF 50V 50mm dia. 80mm height? People use 10,000-12,000uF 63V.
        Computer grade electrolytics are very expensive. Apex Jr. store (DIYAudio) has surplus computer grade electrolytics, store is in Torrace CA USA.
        Snap-ins are much lower cost, but need a PC board to mount to, unless you glue them down. Pic of one kit for the Quad 405, but not sure if still available.
        They make a sonic difference so resist temptation and don't cheap out.
        Ripple current is at audio frequencies, so you need a 20kHz ESR spec that is decent, not just a mains freq. spec.
        • Sparkey55
          • Jan 2010
          • 1523
          I have bought from this eBay seller many times and he is a legit seller.
          Just because he sells on eBay does not mean these are fakes.
            • 31086
            well it's still a good general warning.
            • TechnicsHiFiFan
              • Mar 2018
              • 13
              I am new here, once i can post a thread i will discuss mine,
              to help the poster
              Farnell UK, or Mouser of Digikey if you wish to get other parts, they offer 60$ AU free postage. Farnell is like Element14 australia we dont have much options
              I am not that informed
              how about United Chem Com SMH or KHM capacitors or Cornell Dubilier 380LX, which are nice and cheap at Mouser atm
              http://uk.farnell.com/united-chemi-c...007?st=10000uf
                by sam_sam_sam
                03-31-2024, 02:12 PM
              • captain150
                by captain150
                03-16-2025, 07:34 PM
                by sam_sam_sam
                07-01-2024, 06:34 AM
              • Gust zhang
                Mid 2014 A1398 MacBookPro,Is it feasible to remove the battery from the MBP and connect it to an external power supply?
                by Gust zhang
                ​I have a 15 - inch Retina MacBook Pro from the mid - 2014 model. Here is the link: https://www.badcaps.net/forum/showth...light=820-3662 . The battery broke some time ago. After I removed the battery and plugged in the original power adapter, the MBP could boot up normally. However, when I checked with IntelPowerGadget, I found that the CPU speed was limited to 0.8 GHz, and it ran very slowly. Later, I found a solution on GitHub. There is an open - source project called cputune that can set the CPU running speed. So I can now run the MBP at full speed. But another problem...
                02-16-2025, 08:39 AM
