Capacitor Identification
  • Timelord74
    • Mar 2018
    • 6
    • Ireland
    i need help identifying the value of this capacitor?
    • 30932
    Re: Capacitor Identification
    more pictures needed.
    • Timelord74
      • Mar 2018
      • 6
      • Ireland
      Here is another one..
      • vinceroger69
        • Mar 2012
        • 6714
        possibly this?
        • PeteS in CA
          • Aug 2005
          • 3578
          • USA, Unsure of Planet
          1.2 Farad, 2.7? Double layer carbon type?
          PeteS in CA
            • 30932
            looks right, got the datasheet?
            • Timelord74
              • Mar 2018
              • 6
              • Ireland
              Haven't got datasheet it is for a has got external HDD enclosure..
              I thought it might be a 2.7v 81.2 farad?
              • Timelord74
                • Mar 2018
                • 6
                • Ireland
                Found it using the PL number it is 2.7v at 1 farad
                • Prolog
                  RTX 3080 FE Identifying capacitor
                  by Prolog
                  Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                  I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                  I hope these photos make it clear which component I am referring to:
                  (yes, the soldering is a bit botched from removing the blown one, I know)
                  I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                  12-01-2024, 08:27 PM
                • eastcoastcomputing
                  Capacitor identification
                  by eastcoastcomputing
                  Hi there,
                  Beginner's question, sorry to waste your time...
                  I'm not certain of the values for the capacitor highlighted (on the picture with the tape) as I am seeking a replacement. Am I correct, looking at the schematics) to think it is a 33 pico Farad (pf) 25 Volts? The size seems to be 0201 from what I can assess and when I try to source a replacement, I'm struggling to find one and it doesn't look like something common.
                  Any help or suggestion welcome. This is on an Asus FX506H Quanta NJJ DANJJMB1AA0 Rev 1A...
                  06-04-2025, 05:15 AM
                • Ambro
                  Help identifying missing smd capacitor for HP elitebook 840 g3
                  by Ambro
                  In an unfortunate mishap while attempting to read from the bios chip, one of the smd capacitors took flight and disappeared.
                  I'm not sure how crucial this smd capacitor is, but it was a brown possibly ceramic one with no notable markings on it anywhere.
                  I've attached a picture of where it's located on the board.
                  Does anyone have an HP elitebook 840 g3 who might be able to aid me identifying this component. I'm not sure how crucial it is, but didn't want to risk it.
                  Thank you for any help you can provide....
                  09-09-2023, 06:21 PM
                • grimacelord
                  Need Help Identifying Capacitor On Kar-Tech Versa Remote
                  by grimacelord
                  I have sort of a weird one here. This is the circuit board for a Kar-Tech VERSA remote. It's a wireless transmitter for crane and other heavy equipment.
                  One of the capacitors have blown and I need help finding a replacement. The capacitors are 11.4mm x 6.6mm in size and the only imprint on them is "200mΩF", which I am assuming means 200 microfarads. There is no other markings on them. I have tried doing some searching on digikey and mouser, but I can't seem to find anything like this on there or I am inputting the wrong search parameters....
                  09-08-2023, 09:28 AM
                • anty
                  Lenovo Yoga 13 mb: Yoga 13 MB Panasonic capacitor identification
                  by anty
                  Panasonic capacitor identification...
                  07-07-2023, 01:06 AM
