Any recent feedback for Samwha caps?
  • Ady2017
    • Dec 2017
    • 50
    Hi all
    Do any of you have any recent feedback for Samwha caps?
    I have just replaced 3 bad Capxon caps in a TV power supply with Samwha ones as these where the only ones I could get from my local electronics store. The TV is now working fine with these Samwha caps and I did buy the 105 degree and not 85 degree ones but I am worried they still might be nasty quality and wonder if I should swap them out again for some better ones. Also, if I should swap out some of the others on that board as a precaution.
    BTW: I did buy some other caps from another store the other week that have no brand make on them but am I right that Panasonic do not put their mark on their caps? If so, how do you tell if they are Panasonic or not?
    • 31015
    Re: Any recent feedback for Samwha caps?
    post foto's
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      Samwha are alright. Not the best but far from being the worst. I have replaced a few failed ones in TVs (some have them from the factory) but all sets i've had bulged Samwha caps were over 7 years old.
      A working TV? How boring!
      • Ady2017
        • Dec 2017
        • 50
        Ok, thanks. If they still last for a few years then they will be ok then. I have bought some better ones to keep to one side in case the Samwha ones go. Thanks for the reassurance.
        • Stefan Payne
          • 1267
          Bullshit because people tend to replace good low ESR caps with GP Samwha...
          Not that the quality is bad, just people don't use them right...
          Oh dear...
          What Series?
          Pls don't tell me you used RD Series?!
          Because that's what I have to think about when People talk about Samwha...
          • Stefan Payne
            • 1267
            Because when I read Samwha I have to think about this shit:
            https://linustechtips.com/main/topic...caps-on-a-psu/
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              I have used RD series in SMPS before, but i have checked the datasheets and respected the ripple current ratings - i put more RD caps in to match the ratings of the originals, Those were the only caps i had available at that time. TV's still going 2+ years later.
              • rugger
                • Feb 2005
                • 55
                Th3_uN1Qu3: There is no problem doing it this way though.
                Putting 2 caps in parallel will halve the ESR and double the ripple current capacity.
                But just dropping in general purpose capacitors in place of specific low-esr or high ripple current capacitors without working out if the new caps can handle it is just asking for a quick failure.
                • john111
                  • Mar 2018
                  • 10
                  • britain
                  Samwha are made by samsung and are usually okay.
                  You didn't say what the voltage rating and capacitance of the stock caps are.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Samwha capacitors are not made or owned by Samsung.
                    They are two separate companies.
                    Samsung only make tantalum and MLCC capacitors.
                    • Ady2017
                      • Dec 2017
                      • 50
                      Hi
                      The original ones were CapXon, 1000uf 25v (2 off) and 1000uf 10v. Replaced with 1000uf 25v and 1000uf 16v.
                      I had to get these from Maplins. Can not remember what series they were but they were the 105 degrees ones.
                      https://www.maplin.co.uk/p/1000f-16v...apacitor-dt69a
                      https://www.maplin.co.uk/p/1000f-25v...apacitor-dt70m
                      • Ady2017
                        • Dec 2017
                        • 50
                        The original capacitors were CapXon KF series 105 degrees. Yes, looking at the datasheet they are quoted as being 'Low Impedance'. I already have some 'FR' capacitors which as far as I can make out are Panasonic and look like these are low impedance too so will swap them out to be safe.
                        When selecting capacitors, is it sufficient to match them according to the uF, the Voltage and if they are low impedance or general purpose?
                        • Ady2017
                          • Dec 2017
                          • 50
                          This was quite funny to see as he did a awful job of replacing all the caps with whatever he could find and bodging them in. Looked a right mess afterwards.
                            by momaka
                            03-12-2025, 03:42 PM
                          • eryjus
                            by eryjus
                            05-10-2023, 11:21 AM
                          • Paxman_Swede
                            by Paxman_Swede
                            Hello!
                            01-14-2025, 09:51 AM
                          • captain150
                            by captain150
                            03-16-2025, 07:34 PM
                          • Foetuss
                            Gigabyte GA-6OXT :: caps question
                            by Foetuss
                            Good evening
                            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                            But I was also suprised about the bigger boys, which are 330µF 25V.
                            Could it be they used 25V caps because they were cheaper / available at that time?...
                            02-11-2025, 12:22 PM
