Cap id
  • MEB
    • Sep 2013
    • 371
    Cap id
    Capacitor identification, or at least I think it is one. Looks like C1u0 and 9642. Hope you can read it and help me. Thanks.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4924
    • New Zealand
    Re: Cap id
    It's an SMD tantalum capacitor. 1uF.
    Not sure of the voltage. Nothing in 9642 jumps out at me as a standard voltage. Probably you need the datasheet to find the voltage codes.
    Or just guess based on whatever voltage the circuit runs on.
    Beware that tantalums mark their POSITIVE side with the stripe.
    -David VanHorn
    • MEB
      • Sep 2013
      • 371
      Re: Cap id
      Thank you for the help.
      • PeteS in CA
        • Aug 2005
        • 3578
        • USA, Unsure of Planet
        Re: Cap id
        "9642" might be the date code, in the format YYWW.
        PeteS in CA
        • Agent24
          I see dead caps
          • Oct 2007
          • 4924
          • New Zealand
          Re: Cap id
          Oh yes, the date code. That would make sense...
          The leading "C" might be the voltage code, then?
          -David VanHorn
          • redwire
            • 3900
            Re: Cap id
            "A" logo I think is older AVX. Voltage code C is (for AVX parts) 16V.
            You can also estimate from the IC's operating voltage.
            Tantalum capacitors need a huge voltage derating like 50% for long life. So a 5V IC would have a 10-16V part for decoupling.
            • PeteS in CA
              • Aug 2005
              • 3578
              Re: Cap id
              Speaking of voltage derating, if you're using X7R ceramic caps and don't want much variation due to the voltage coefficient the rated voltage should be 10X the circuit voltage.
              PeteS in CA
              • MEB
                • Sep 2013
                • 371
                Re: Cap id
                Right or wrong, these are what I ordered as a replacement.
                TAJA105K035TNJ
                • Fernon@Repair
                  Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                  by Fernon@Repair
                  i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                  VCCIO voltage ok
                  VCCSA Voltage OK
                  VCCPLL Voltage OK
                  Ram Voltage ok
                  RamVTT OK
                  VPP 2.5 OK
                  But No Core Voltage
                  and i want to this vrm ic datasheet or pinout (ISL69269)
                  anyone have this ic pinout voltages?...
                  06-25-2025, 07:19 AM
                • electron_jj
                  Panasonic TH-L42D25A checking the PSU output voltage
                  by electron_jj
                  Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                  I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                  08-29-2021, 08:13 AM
                  Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                  by sam_sam_sam
                  I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                  The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                  Now...
                  06-09-2024, 10:57 AM
                  ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                  3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                  Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                  core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                  configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                  serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                  Based on Intersil's Robust Ripple Regulator...
                  11-05-2024, 03:24 PM
                • ruletero
                  Acer a515-43 low battery charge voltage
                  by ruletero
                  Hi
                  Acer A515-43
                  LA-H801P
                  Fail: Does not charge battery, has low voltaje on connector.
                  Laptop didn't want to turn on, only charge led blinked.
                  I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                  I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                  Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                  10-24-2022, 02:31 PM
