Tantalum Capacitor desoldering- safety concerns
  • Alex_Santos
    • 11
    • Poland
    Dear members
    I have the TS100 soldering iron, not a tweezer type and some tantalum capacitors that I need to remove.
    Considering the tools I have, desoldering braid, flux and the iron but are there safety concerns to account for? Namely the tantalums blowing up? I will use glasses but I wanted to know if this is legitimate concern or an event that happens with very little frequency.
    Kind regards
    —Alex
    • 31063
    Re: Tantalum Capacitor desoldering- safety concerns
    they dont blow up, they are just a lump of tantalum in a plastic box.
    removing them with an iron wont be easy though, the contact wraps under the cap body.
    • R_J
      • 9551
      You will be fine, the capacitor will not blow up. A tantalum cap can blow if it becomes shorted when voltage is applied to it, it wont blow while soldering or desoldering
      Use extra flux if you can, that will help the old solder flow when heated, and be careful to not put too much force if you are lifting it so you don't lift the trace with it.
      • Alex_Santos
        • 11
        • Poland
        Thanks stj and R_J. I desolder my first tantalum. What appears to be 10x harder are the small electrolytic caps, man are they ever tough to remove. I avoid bending or rocking the cap, maybe that's why but I can't risk damaging the pads.
        Thanks again!
          • 31063
          smd electrolytics are a bastard, there are a few methods used - each has pro's & cons.
          i like to twist them to break the legs - then desolder the legs
          sometimes the legs just pull away from the pads as you twist.
          • Alex_Santos
            • 11
            • Poland
            Some folks really are against this as pads might come off as a result.
            Maybe I just have to purchase desoldering iron tweezers, they can come handy in these cases, at least for me.
            Thanks again!
            • mariushm
              • May 2011
              • 3799
              I find the easiest technique is to just add a blob of solder on each pad / leg then with the iron tip hot, alternate between the ends for a few seconds at a time to keep both blobs hot and gently push on the capacitor with something (a toothpick, a tiny screwdriver, a dentist pick, a spudger, whatever)
              Afterwards you can use some solder wick or whatever you want to clean the pads.
                • 31063
                alternating can also lift pads, there is no 100% safe method other than hot air.
                that brings it's own problems, you have to puncture the can first or it can explode!
                and obviously it cant be close to any other electrolytics or plastic such as connectors.
                • Alex_Santos
                  • 11
                  • Poland
                  Guys, I figure out a method.
                  I put an ample amount of flux and then soak fresh solder onto the pads. Then I heat up with 400°C which is what I found works. I alternate between sides with the iron while gripping the cap with small players. As I draw heat to each side I gently wiggle the cap until it begins to lift on one side. If needed I add more solder as this creates a nice heat reservoir.
                  After two minutes the cap is off, I clean up the excess solder with a copper braid and then clean with isopropyl alcohol.
                  This appears to work quite well for me and so far I removed about 8 caps, 2 wants and 6 electrolytic.
                  I appreciate everyone's advice and support as this is my first attempts on a test logic board that got destroyed beyond economical repair by a leaked battery.
                  Thanks everyone.
                  —Alex
                  • Alex_Santos
                    • 11
                    • Poland
                    Just a quick follow-up on my process.
                    1) add a liberal amount of isopropyl alcohol around the cap
                    2) add flux to both the + and - side of the cap
                    3) With the iron already hot, contact the terminal and add a good amount of solder to both sides
                    4) Alternate back and forth between each side while gently rocking or lifting the cap. This relies on my sense of feel but I maintain a gentle tug while alternating.
                    This has proved the quickest method for me. I have pulled 20+ caps since my last post thanks to all of you who volunteered your strategies/recommendations. I couldn't have done it without your advice.
                    After spending countless hours watch PACE videos, EVBlog videos I finally feel like I touched down, touching metal for the first time and the satisfaction is immense.
                    Thank you all for helping me along this new journey. I love electronics and I am in my diapers still but everyone's help has been critical and supportive.
                    Best regards
                    —Alex
                    • Prolog
                      RTX 3080 FE Identifying capacitor
                      by Prolog
                      Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                      I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                      I hope these photos make it clear which component I am referring to:
                      (yes, the soldering is a bit botched from removing the blown one, I know)
                      I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                      12-01-2024, 08:27 PM
                    • chth96
                      If I replace with inferior capacitor, Is it No harm to other IC components at all?
                      by chth96
                      I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                      Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                      It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                      So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                      I know that these capacitor will not last as long as nichicon capacitor...
                      12-22-2023, 04:34 AM
                    • chth96
                      How can I test non-polarized capacitor?
                      by chth96
                      I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                      I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                      And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                      I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                      06-02-2024, 07:31 PM
                    • chth96
                      Is it no harm to replace with capacitor without ripple current rating?
                      by chth96
                      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                      Rubycon YK DataSheet (b...
                      04-19-2024, 05:19 AM
                    • chth96
                      Should I replace polymer capacitor?
                      by chth96
                      a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                      I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                      Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                      Is this ESR value of polymer capacitor correct?...
                      11-18-2022, 04:22 AM
