Just wondering..
  • Solder Boy
    • Nov 2006
    • 178
    Just wondering..
    How come some boards boot up perfectly fine with bad caps, yet when you replace the bad caps, the board doesn't boot anymore? After a run of 13 successfully repaired boards I'm into my 3rd failure.
    Are some boards more flakier than others?
    www.bcrelectronics.ca
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Re: Just wondering..
    Maybe you have made a mistake, a short circuit or you have broken a track.
    I don't see any reason why a board shouldn't boot with good caps unless something happens during recap.
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      if we are talking about boards working before recap
      can try bios reset
      otherwise what equipment are you using
      • Wizard
        • Mar 2008
        • 2296
        Solder Boy,
        Also this DEPENDS on certian brand of boards, some is so low quality (aka pc chips) that it took massive pile of electros and MLCC capacitors, some are SIMPLY BAD to begin with because many surprise, surprise knowingly used rejected chipsets.
        Remember, the chip makers (not intel or amd), sells off rejects and expected them to be used in low performance stuff but some of them pass it off as same as geniune item and you get issues in the end.
        Still is with memory especially with generic brand and no names on the market.
        Notice many had blank chips (no evidence of grind off or painted over) and used "internal" markings on them? Sometimes ground off or simply scribbed over the original. Those are rejects. Azza, GB, etc are those offenders and most espeically seen in big boxes stores like Best Buy, staples etc.
        Cheers, Wizard
        • Solder Boy
          • Nov 2006
          • 178
          can try bios reset
          Hi, my present set up is this, adjustable soldering iron, it's set 3/4 of the way to remove caps, and I lower the temp somewhat when installing new caps.
          Other gear includes dental pick, desoldering pump and as of today an overhead magnifier ( thing that sits on your head) to inspect solder work.
          Everything comes off the board when I work on them, CPU and battery.
          Also due to the fact the humidity level is low this time of year I use my service tower as a grounding tool to discharge any static electricity before working on a board.
          Worked on an MSI this morning before work, replaced four small blown caps and the board still worked!
          • ugamazing
            Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
            by ugamazing
            I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
            We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
            12-17-2024, 07:05 PM
          • privato89
            Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
            by privato89
            I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
            Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
            Let's begin:
            Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
            03-26-2024, 06:37 AM
          • hinisa
            Xiaomi router freezes at boot after re-capping
            by hinisa
            I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
            When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
            After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
            Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
            07-08-2023, 05:58 AM
          • Luke Anders
            Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
            by Luke Anders
            A few details about the laptop itself:
            Name: Lenovo Legion 5
            Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
            BIOS Version: GKCN60WW
            EC Version: GKEC65WW
            Serial Number: PF39AQ7Z
            Board Model: NM-D562 Rev 3.0
            RAM: 16GB Installed, DDR4 (brand new)
            NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
            I bought this laptop recently from eBay as a faulty device....
            10-12-2024, 05:13 AM
          • NolesFan
            Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
            by NolesFan
            Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
            10-24-2024, 06:36 PM
