2 capacitors in parallel vs. single capacitor
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I need a bit of advice on how I should go about replacing two dead capacitors on a Samsung power board. Wasn't too sure whether this belongs in the TV repair category or capacitor questions, but I settled on the latter thinking it's really a general topic that can apply to various projects, not just power supplies, so here goes:
    Without going into too much detail (since that would pertain to the TV section), I need to replace 2 electrolytic capacitors which have failed on the primary of a Samsung power supply. Sounds like a simple task, but the capacitors have an unusual value - 56uF which I couldn't find at my local shop so I was wondering what the best alternative would be. Caps in parallel, as far as I know, add up, meaning I have 112uF there really. Should I go with two capacitors of the nearest higher value (which I THINK is 68uF for a total of 136uF, which is higher than 112uF), or should I go with a SINGLE 120uF capacitor instead, which is closer but still higher ? Of course, they'd be within the 450v requirement of the original ones, so don't bother with that. I don't have any pictures of the board right now, but it's got a PFC booster if that makes the least bit of difference....just in case some tech gurus will immediately point out something really technical related to that which might make either option unfeasible. Cheers guys.
    Wattevah...
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: 2 capacitors in parallel vs. single capacitor
    electolytic capacitors have big toleracne,sometimes 20% and higher capacity is always better :-) so use what you have in hand..
      • Jul 2011
      • 6033
      Can you find a 47 and a 68 UF cap that would very close I have seen this in power supply before
      I do not think that it would mater if it is a little over if it this is the main filtering caps
      so you could even use 2 68 UF cap as well I would think
      • Stefan Payne
        • 1267
        In General:
        If you only need the capacitance, doesn't matter.
        If the cap is highly stressed, more is preferable.
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          I might be able to do that, but wouldn't something bad happen along the way if they're imbalanced like that ? Yeah, you guys are right, main caps like these don't usually undergo a lot of stress (I believe they call that "stress" dv/dt in technical terms ? I may be far off there). These ones only blew because of a power surge, taking some transistors out with them. Varistor didn't go...bad design at its finest IMO >_>
          Wattevah...
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            Tv is now working with two 68uF caps in it Success
            Wattevah...
            • Prolog
              by Prolog
              12-01-2024, 08:27 PM
            • GKdays
              Single capacitor replacement on arcade pcb
              by GKdays
              I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
              10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
              I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to...
              08-09-2022, 05:21 AM
            • goodpsusearch
              Sony RCD-W3 Deck A (Playback only) not playing CDs (Disk Error) repair
              by goodpsusearch
              Recently I was given for free a Sony RCD-W3 with the following symptoms, CD recorder drive reads CDs without any issues (haven't tested recording function yet because I don't intend to burn CDs on that machine) but the reader drive shows disc error after some seconds of it trying to read CD. Tried both CD-Rs and commercial audio CDs with same results.
              First thing to do was to clean the lens but that didn't change anything. Googling the issue revealed that this is a common issue on several Sony CD recorder machines and the culprit is SMD electrolytic caps located on the PCB bellow...
              05-05-2024, 02:04 PM
            • chth96
              by chth96
              12-22-2023, 04:34 AM
            • chth96
              by chth96
              06-02-2024, 07:31 PM
