Capacitor leads that won't come out..
  • Solder Boy
    • Nov 2006
    • 178
    Hi well I ended up killing a perfectly good P4 motherboard today...
    It had a whack of blown caps by the CPU socket, everyone came out except for this pain in the butt. The one lead busted off the capacitor and was stuck in the hole.
    I tried using the iron and small tweezers to try and get it out to no avail.. even tried adding fresh solder and trying to get it out that way with my solder puller.
    Anyone ever had this problem? What did you do? Thanks!
    www.bcrelectronics.ca
  • gdement
    • Jan 2007
    • 690
    Re: Capacitor leads that won't come out..
    I've had it happen, but was always able to get it out with pliers.
    If that cap is in parallel with others, then you should be able to live without it as long as you can keep the total capacitance up near where it should be. Just use bigger caps in the remaining spots, and also be mindful of the combined ESR (which is divided by the number of caps installed).
    If you see any unpopulated positions nearby then check with a multimeter, they might be on the same circuit as the one you lost.
    If these are Vcore caps, then the loss might not be critical if you aren't running the top-end processor. Something with less current draw, higher voltage, or broader tolerances won't be as demanding from the caps. Also using lower ESR than the originals can reduce the required capacitance, at least on Vcore.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      I agree with gdement.
      You can also try using a stainless steel needle + solder iron heat to push it out.
      If you abandon the spot then make sure you clean the area up well.
      Don't leave any surplus solder to short traces.
      Mann-Made Global Warming.
      - Dr Seuss
      • Huckfinn
        • Jan 2009
        • 43
        Solder Boy:
        You do not indicate what type of soldering/desoldering tool[s] you are using. Not to be a funny man, but your name being what it is, you may want to try using soldering and desoldering equipment made by Hakko [or Pace if you like]. You should then not have any problems removing caps from motherboards. Check out their respective web sites. They make awsome soldering/desoldering tools. I especially like Hakko. They are pricey, but well worth it.
        Huck
        • Solder Boy
          • Nov 2006
          • 178
          I use a Weller soldering station with adjustable heat setting. I also use a tool called Soldapullit, to suck up the molten solder. I had my iron set at a high enough temp to get the caps out quickly without heating the board unneccesarily, so I was a little surprised the one didn't want to come out at all.
          I get enough dead or unwanted MOBO's in my line of work so I'm going to brush up on my skill.
          Thanks for the info everyone
          • Nier
            Drilling out solder from capacitor holes
            by Nier
            I have an xbox 360 board that had 4 leaked electrolytic capacitors. I desoldered all 8-10 capacitors (1500uf 16v) since 4 leaked and wanted to replace all of them. 2 capacitor legs broke and were stuck in the through hole.
            My two solder suckers just didn't work and I decided to use my dremel lite in the lowest speed to drill out the broken capacitor legs. I used a carbon drill with the exact diameter size as the capacitor hole. I drilled out the capacitor legs but I think that I damaged the holes. I don't think that the solder will adhere through the hole if If I solder a new capacitor....
            10-05-2021, 09:48 PM
          • Prolog
            by Prolog
            12-01-2024, 08:27 PM
          • chth96
            by chth96
            12-22-2023, 04:34 AM
          • chth96
            by chth96
            06-02-2024, 07:31 PM
          • chth96
            Is it no harm to replace with capacitor without ripple current rating?
            by chth96
            When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
            Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
            But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
            Rubycon YK DataSheet (b...
            04-19-2024, 05:19 AM
