Bad Caps in a MONITOR?
  • Kelarius
    • Apr 2005
    Hello, im new here but I've dealt with bad caps on MBD's before (ex-gateway tech support). Im trying to fix an NEC 17' LCD display that wont start up and simply just blinks the sleep light on the fron VERY FAINTLY whenever you try to power it on. So i pull the thing apart and lo and behold, there is a cap on one of the boards thats bulging and oozing out of the top. In your informed opinions, do you think this could be the source of the problem?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    What brand is the cap? The cap may be the source of the problem. However, it might also be the aftermath of shorted regulators or something else that caused it to blow.
    I've never even seen the inside of a LDC monitor, so I can't speak too intelligently on how they work. Post some pics.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      very common.
      i have an nec with choyo 330@25 caps blown up.
      yes the same crap gigabyte puts on mobo's.
      change them out and it wil be ok
      btw tc many lcd run from 12v dc and use buck converters to get +5 +3.3 ect.
      the ccfl driver runs from raw 12v
      • Kelarius
        • Apr 2005
        well the bad caps are labeled as "Elite", dont know if that is the manufacturer, the monitor is an NEC MultiSync 1720M, and the 2 bulging caps are both 1000uF and 35v and 16v respectivly
        unfortunatly i dont have a digital camera that works right now otherwise i would post some pics.
        • mrbill08
          • Dec 2008
          Re: Bad Caps in a MONITOR?
          I can confirm. In the two NEC MultiSync LCD1720M monitors that I repaired, there were actually 3 of these guys all in the same area - two were 1,000uF at 16V and one was 1,000uF at 35V. They were all "domed" on the top and one had electrolyte that leaked out. Did not take any pics unfortunately. They were radials. I replaced all three and that did the trick for both monitors.
          Bill
          • SJPinoy2001
            • Feb 2009
            Hi there - I'm so glad to have run across this thread. I unfortunately am not on the technical side, but do have the same if not exact symptoms/issues explained here. Would you mind possibly giving me a step by step guide to fixing my monitor like you did? Where can I buy these caps and how much would/should they be?
            Thanks a bunch!!
            Ron
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Elite are junk and common in LCD screens. - Just replace them.
              Mann-Made Global Warming.
              - Dr Seuss
              • black6host
                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                by black6host
                Good day!
                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                I'm going to replace the caps and I'll be the first...
                02-06-2024, 08:22 PM
                by momaka
                03-15-2023, 10:17 PM
                by momaka
                03-12-2025, 03:42 PM
                Westinghouse L2210NW LCD monitor - bad caps repair
                by momaka
                Here's another LCD monitor repair: Westinghouse L2210NW.
                Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                Pictures of the monitor outside/case after a brief...
                01-11-2021, 01:14 AM
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
