I have a Tesslor R601 radio I took apart to see what it was made of and noticed that the main caps were 220uf 400v but the pcb had 100uf 400v printed on it. Also there were 2x 22uf 250v caps but the printing said 10uf 50v on one and 10uf 250v (IIRC) on the other. Given that some boards get revised and updated to new specs, is this fairly common? Just seems odd to me , being a noob. Thanks id advance.
Silkscreen cap values vs installed
Re: Silkscreen cap values vs installed
May be normal also if they for example made more powerfull model later on the same PCB, so they just upgraded components.Less jewellery, more gold into electrotech industry!Half of the computer problems is caused by bad contacts
Exclusive caps, meters and more!Hardware Insights - power supply reviews and more!
by proxneoDear reader
I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
At the moment, I have selected replacements based on the following list of values:
3 x 470uF 10VDC
3 x 4.7uF 35VDC
4 x 47uF 50VDC
8 x 22uF 6.3 VDC
1 x 220uF 6.3VDC
5 x 100uF 6.3VDC
Which...-
Channel: General Capacitor Questions & Issues
by Perry BabinThe attached capacitors are used in the output filters of class D amplifiers and hold up well but when they fail, replacements are difficult to find. I've tried the various options on eBay and crossover caps and none survived. Mouser, Digi-key... don't stock many bi-polar electrolytic caps. The only thing that I found survived (never a failure) was the Mouser E2106 (part number 667-ECQ-E2106JF) and the same from Digi-key. They look different but survive. Does anyone know a readily available drop-in replacement electrolytic? The dimensions are approximately 16mm x 25mm....
by rashidjafarI am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
Values for :-
PC43 : Capacitor [3x1.5mm]
PL7 : Inductor [2x1mm]
PC39 : Capacitor [1x0.5mm]
Any ideas would be appreciated.
I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors.... -
by KobokDear Alls,
For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103... -
by JohnNovakHi.
I have some problem with old CRT TV Samsung model: CW-29Z338T, 29" size TV.
The problem is that letters and other text are not clear, text or letters are shadowed on the right side.
I found 2 capacitors on CRT Picture Tube Board.
47uF/400V was leaking very bad, the second cap 10uF/250V was bad ESR reading so i replace this cap also.
Replacement these 2 capacitors did not help nothing.
I try to reduce brightness, contrast and sharpness. There is very small effect on this shadow.
To reduce G2 down have more effect...-
- Loading...
